Can I use 20A plug for power to soffit lights
pauls340
North of Motown
I have a 20A double gang plug on my front porch, only thing on that circuit. Can I tap onto that plug and run the 14-2 romex into the basement to power 4 small soffit lights? It's just closest to the lights. Thanks
pattenp
Virginia - USA
If the 20A outlet is in fact on a 20A circuit then no you can not extend that circuit with #14 wire. The wire needs to be #12. Also if the 20A outlet is outside it needs to be GFCI protected.
P
pauls340
North of Motown
Breaker box isn't full but this project is over budget and I don't want to run the wire over to the box for a new circuit. So I have a length of 12-2 romex. Can I use that to tap off the plug then daisy the four lights with 14-2? Or is this not good or safe? I do have another plug that's 15A that I can tap into.
cmorgan
Kansas
Replace the breaker with a 15amp and you will be up to code and able to use 14ga wire. Or use 12ga and use the existing 20 amp circuit.
P
pauls340
North of Motown
But if I use the 12-2 to get power from the plug to one of the lights, then can I use 14-2 between the lights and the switch?
eljefino
No you can't have 14-2 anywhere unless you change the breaker ($4). Or if you put in a "subpanel" with a 15 amp breaker at the end of the thicker wire.
Hey, odds are good you won't plug a 20 amp thing into that outside outlet.
pattenp
Virginia - USA
You can do what ever you want. Doing it the way you're asking won't be to code. The only wire that can be smaller than the circuit size is a short tap to the light fixture from a box and the tap has to be sized to handle the load of the fixture.
P
pauls340
North of Motown
It would be easiest to change the breaker to 15A and leave the 12-2 from the panel to the outside plug and just use 14-2 everywhere else.
P
pauls340
North of Motown
No objection, it's just I ran 14-2 to each of the four lights and then decided not to use the power source I originally thought. The next closest is this 12-2 outdoor plug. By changing the 20A circuit to 15A, I can leave the 12-2 where it is, tap into the plug with 14-2 and leave the four lights daisy-chained with the 14-2.
Speedy Petey
NY State
Changing the breaker is dumb. WHY would you throw away 5A of potential circuit capacity because of a mistake?? Also, depending on what it feeds the 20A circuit may be required.
Do the right thing, change the wire or change your feed point.
Speedy Petey
NY State
Here's a pic
If that is how you wired it it's not going to work. You need to either bring the feed to the switch, or make it complicated and run 12/3 between the feed, lights and switch.
What is your level of expertise? Have you done any electrical work before?
