Can I weld up these holes?
1930artdeco
Lynden, Wa
I have these holes in the side of my rocker panel on my car. Can I weld them up or do I need to cut the area out and replace it?
Rockable
Oak Ridge, NC
If you're able to do it, it will likely be distorted and the rust will come back. If you could see the inner side, you would see a pitted piece of metal with thick and thin portions. You won't weld up all of the pits because they haven't all rusted through yet. If you want this to last, cut it out and put new metal in it's place. It's always worse than it appears.
There are lots of threads and videos on the web that tell you how.
1930artdeco
Lynden, Wa
Thanks, I have two plans for this area: 1) weld up the holes, 2) cut and weld in a new piece. Obviously the first is easier. I can get to the back side and it is ‘rust free’. But it is thin so it may come down to plan B.
slowtwitch73
Hellgate
You can drill them bigger with a step drill to get to good metal, then get a scrap bolt and thread it though, mig and cut off the bolt and grind down... or cut the bolt before hand to give you a little plug.
APEowner
Sunny, New Mexico
Yeah, you should cut that out. You should also be prepared to find matching holes in the inner panel that also needs to be cut and patched.
gte718p
I have no idea if you can or can't. They can be welded. Can you? Should you?
I looks like a flatish section with no complex curves. I would probably cut an patch.
FLHCHAZ
Do yourself a favor and put in a patch. Trying to weld and grind thin, rusty sheetmetal if going to be frustrating. Even if possible.
djbmw
Ottawa, Ontario, Canada
Do you want it back to original... or do you want it to look good quickly? If the later just fiberglass it after neutralizing the rust.
If the former then shape a new peice of metal to cover the entire area thats rusted + 3 additional inches in all dimensions, mark and cut the existing metal, and tack in the new one (tiny tacks at opppsing sides so minimize distortion).. you will likely still need to reshape the new metal with body hammers and dollys once its welded in.
Imatk
Fitzees is AWESOME.
I will add.. when you cut to good metal and weld. I'm not sure if you're looking to grind the weld flat.
But if you do, be careful not to thin the area around where you grind.
If it were me and it was possible to get to the backside of your sill I'd weld it from the back and then you'll have less (if any) to grind.
Make sure you shine a light behind the new welds... pinholes are pesky and will lead to more rust if left open.
Milton Shaw
IF your car is a classic car, JC Whitney may have patch panels already cut to fit normal rusted out panels.. You just cut the original metal and then trim the patch panel to fit and weld it in with small tack welds and eventually stitch them together. Grind and finish, Bondo and sand and it's finished.
