Can I wire Dayton G73 on a regular light switch using 10 awg wiring?
fergie_1977
Petawawa, ON. Canada
Hey folks,
Looking at buying a Dayton G73 electric (5000w) shop heater.
Can I put the 30amp breaker in my panel, run 10awg wiring to a light switch, then continue from the switch to the heater with 10awg?
This way I can turn the unit on and off with the light switch.
Is there a specific switch I should be useing?
Am I nuts to have that much juice flowing threw a wall box / switch?
Open to any suggestions!
royalton10
Lancaster, Ohio
I bought a 240v light switch, cost of about $25 (bought from local electrical contractor type store, stayed away from the box store, wanted to get this one right the first time) compared to $1-3 for regular 120v light switch. I did the exact same thing you are doing but I also put a dial type thermostat right beside the 240v light switch.
All of my outlets or light switches were almond, I bought the black 240v light switch to help denote a difference in the shop.
F
fergie_1977
Thanks Royal.
Would you happen to have any pic's?
Sounds like a carbon copy of what I want to do.
Was it hard to add the t-stat into the mix?
royalton10
Lancaster, Ohio
First attempt to attach pictures, we will see how well I do.
Doug
Lancaster, Ohio
F
fergie_1977
Pictures are great...exactly what I'm looking to do.
Thanks for posting. Did you have to do any modifications to the unit to add a thermostat to it?
royalton10
Lancaster, Ohio
Ran 10-2 with ground from panel to light switch, jumper from light switch to thermostat (junction boxes for both switch and thermostat were in the same wall cavity) Then it was 10-2 with ground from thermostat to heater. I think this was the route.
weicm3
thanks. so, the thermostat is inline 240v one that doesn't need transformer? and between thermostat and g73 is 2 hot and 1 ground?
do you just set the built-in thermostat on g73 to the max and let external thermostat to supply and cut power?
I remember I saw the post somewhere saying g73 has a feature to run the fan for a while after temperature is reached(I guess power to heating element is out but still sends power to fan). does your wiring disable this feature?
royalton10
Lancaster, Ohio
I did not use a transformer. I do not remember if I did anything with the dial. Fan runs for a few minutes after heat kicks of. Wiring did not disable the fan.
2LTim
Central Iowa
Doug:
I usually hang out over in the electrical section, but just happened to be checking out other sections. You did a nice job of installing your heater, it looks great! Give yourself a big pat on the back for attaching the pics!
My question is this: If your switch controls power to the t-stat, and the t-stat controls power to the heater, how can the fan continue to run after the wall mounted t-stat has been satisfied and cuts power to the heater?
P.S. Any big box store electrical dept employee who wears his hat straight should be able to hand you a 30 amp DPST (Double Pole Single Throw) switch a.k.a. 30 amp 240 Volt switch.
Tim
Falcon67
Merkel, TX
I would search here for ideas on transformer t-stat hookups. It'll save money on wire. The best way is to wire it in where the built in t-stat goes so the unit continues to work as designed. I own a G73 and it is supposed to run the fan a bit after the heat is off - the unit is built like that. The internal t-stat works well enough IMHO. If you put a switch in the power line, I would use it strictly as a disconnect. Locally, HD has a better selection of two pole switches than Lowes. My ceiling is 8', so I just reach up and turn mine off with the dial on the way out the door.
jvitez
Big Sky Country, Canada
It's a small point, but if you plan on a remote t-stat installation, you could save yourself the cost and work of wiring in the 30 amp switch by just buying a DPDT t-stat instead of a DPST. The DPDT has an "off" setting. That's assuming you have the heater wired with a twist-lock plug to act as a disconnect. If it's hard wired, I'm not sure if a DPDT t-stat would be approved as a disconnect, maybe someone who knows could chime in.
royalton10
Lancaster, Ohio
Tim in Iowa,
Thanks for the kind words about the install. I may have described the wire routing incorrectly, not sure. I did have a electrican friend of mine walk me through the proper way to wire. It does work.
I got lots of feedback and help last year during my install.
Thanks again!
royalton10
Lancaster, Ohio
The switch is designed to be the kill switch as thermostat location is about 12 feet from the panel box. But the panel cannot be seen as a short wall is in the line of sight. The previous owner had a closet framed in that I assume was meant to be designed as a closet for an air compressor. It was easier to rip out the door framing and leave in the short wall.
royalton10
Lancaster, Ohio
Falcon,
Thanks for all of your help as I was installing the G73 heater last winter. I had asked you lots of questions with several posts last winter. Your help was greatly appreciated.
Some pictures of my install are shown above in this same thread.
Thanks!!
micwazoo
Royalton10, if your electrician buddy could verify the way he wired, it would be much appreciated. I'm doing the same thing this weekend, and want to make sure I do it so that the fan continues to run after the heat goes off so I don't ruin the heater element.
Thanx,
royalton10
Lancaster, Ohio
Micwazoo, My electrician friend is out of state. I had big time trouble getting all of the wires in handy box since it was 10 guage. I am not going to open up the box at this time. Sorry.
You will certainly enjoy this heater.
