can light grease be subbed for antiseize compound
APEowner
Sunny, New Mexico
It really depends on the application but in general if antisieze was the correct product in the first place then no, grease is not an acceptable substitute.
RunninOnEmpty
New England
I would say never use any sort of grease on threads unless specified by the manufacturer of the part you're fixing (which is extremely rare).
wnstwolf
New York and PA
One real world test that I know a few of you may have run into is removal of sparkplugs and in my case I took on a job for a F-250 V-10 motor. this was a 105k mile motor and these are known to be big trouble. at 55 k the owner replaced the plugs and said he used Anit Sieze on them. 9 of the 10 plugs broke but one came right out. the one that came out still had signs of the anti sieze on it. I got ahold of the owner and asked what he did wen he installed the last ones and he said he only had a little Anti Sieze left and the rest had hi-temp grease. Looks like the heat of the engine quickly burned up the grease but the As was like it was just put on and really worked!
MACK tools seels a great kit used to remove these notorious pulgs. I now have another tool I may never use again but got the appreciation of the AS benifits as an added bonus..
Use the right stuff/tool for the job!
R
redbarron57
Its not on threads its on a shank that does not move. It does not matter cause I found the right stuff.
WVBrady
WV
I have read not to use grease, because it will cause thermal insulation and result in the plug running hotter. I think the metal in the anti-seize conducts the heat away better. Of course, some plug manufacturers claim they already have their own type of anti-seize added.
redmondjp
Redmond, WA
+1
And you only need a tiny bit of anti-sieze - I put a dab on one plug and match the threads with a second plug and spin them against each other to spread it out evenly.
katy
I find it to grainy and thick
One place I used to work at (for 12 years) we used lots of it, ifn it was too thick we just mixed a little oil in it to thin it. Never had any problems with the thinned stuff not performing.
404
Mass
+1
Very clever way of doing it.:thumbup:
