Can RaceDeck hold up a lathe?
JackOfDiamonds
Idaho (USA)
I have a 2000 pound metal lathe. Normally it rests on 6 stele machine feet, but sometimes I put it down on 4 steel caster wheels and roll it away from the wall to get to the back.
Could RaceDeck stand up to something like this? I'm guessing not, but I've seen people put car lifts down over the stuff, and some other surprising things.
Roert42
NE Penn
I’m interested in seeming some feedback on this too. I reached out to them on their website with a similar question and haven’t gotten a response. Been about a month.
RoninB4
Under My House
-No experience with Race Deck but I had a look at their website. Only saw the open patterns, don't know if there's others that are of a closed geometry pattern. My first thought was "What a great way to trap machining chips". Yes many of the chips can be sucked up with a vacuum cleaner but chips often cling tenaciously to/under anything they can. A few places I've worked had fatigue mats similar to these and the only way to clean up after machining was to pick up the entire mat with an overhead crane and knock all the chips/curls loose for sweeping. You never get all of them either as the sharp edges embed into the rubber/plastic matrix so you just did the best you could and left what remained.
-Could these support a lathe? That depends upon the footprint area of the feet themselves. Obviously the larger the footprint the less imprinting. Will the mats allow for rolling? I suppose so but wouldn't expect a firm answer from anybody but sales to tell you so, liability makes everybody but sales a bit reluctant to commit to an answer. Ease of rolling also depends on the caster but I wouldn't feel comfortable with it until after I'd done it a few times. I use feedback from the casters when I roll on concrete and the odd surface would be a new learning curve. Almost all lathes are decidedly top heavy and I need all the feedback I can get to tell me when something hangs up a caster from rolling (like chips) so I don't keep shoving, it doesn't take much effort to push a top heavy machine over or lose a caster that's not bolted on. If the mats separate and leave a gap I can imagine the caster falling into the gap and cause a heart stopping disaster. Maybe I have an over-active imagination or too many similar experiences on the job.
-Would I advise using these mats? Can't speak for or against them. They seem nice but for reasons I've mentioned I wouldn't use them around machinery until my questions were answered and/or I tested them. They seem nice but that's probably a large, expensive chance. That's just my personal opinion. If you get them do report back, I'd like to know how they worked out over time.
Spud McGee
How much time you you put into leveling and aligning your lathe? I use a machinist level that measures 0.0001" out of level over 10" span.
To dial out taper, I am raising and lowering the feet and shimming in increments of 0.001". I doubt very much that race deck will be stable enough to have a heavy, vibrating machine on it and not shift by a thousandth of an inch.
If you are talking about a wood lathe, or you have a metal lathe but just dont care to align it that well, then maybe its not a concern.
Denwood
Thunder Bay, Ontario, Canada
If you have the six steel pads in turn on plywood 12x12 squares you would have no issues. Rolling heavily loaded steel castors over free flow would a bad idea unless again you lay down some plywood. On the solid flooring, I suspect 2000 lbs over steel wheels would damage it as well.
I'll regularly load up vehicle stands on the free flow floor (so 1500 lbs max) but I do have the jack stand on a 3/4" piece of plywood (around 20" square) for the three steel legs to sit on.
Remember that folks are driving 8000 lb trucks over this stuff with just four small contact patches...but the tires are rubber and can deform a bit to the floor. Steel castors, not.
American Locomotive
Rhode Island
2000 pounds, spread over 6 feet. That's 330 pounds per foot. If each foot is 2" diameter, that's about 100 PSI of force each. Looks like the RaceDeck Literature says it can withstand 250 PSI.
But I don't really know what that means. Is it 250 PSI before it starts deforming in any meaningful way at all, or is that 250 PSI before it's completely crushed and useless, meaning it likely crushed more prior.
