Can/should this oxidation be removed?
jives
Central NY
Picked up a the local Re-Use store a Weatherguard Defender 800 lb. capacity aluminum ladder rack. $8.00. Yup. Could not leave well enough alone and figured I needed to check the fasteners, etc. The cast aluminum seats for the rack legs are shown. They are pretty well oxidized. I tried removing with Rustoleum rust dissolver gel (phosphoric acid, I think. Listed on the back that it would work on aluminium). Did not dent it. But, do I really need to remove? BTW, the rust stains are from the fasteners.
OccupantRJ
Eastern North Carolina
I use a blast cabinet and follow with a few coats of spray can clear on items of that nature. It ends up with a wet primer color look. I use the method as a customized finish. The bracket in the picture with the four bolts was done this way.IMG_3847.png
J
jives
Central NY
Okay, so no blasting cabinet, agree on the no-go for strong acid, and using a wire wheel on all the crevices. . . uggh, no, does not look like an effective use of time.
Internet shows a bunch of chemicals. Aluma brite, vinegar, etc. Anyone with good experience with them or something else?
