Can/should this oxidation be removed?
jives
Central NY
Picked up a the local Re-Use store a Weatherguard Defender 800 lb. capacity aluminum ladder rack. $8.00. Yup. Could not leave well enough alone and figured I needed to check the fasteners, etc. The cast aluminum seats for the rack legs are shown. They are pretty well oxidized. I tried removing with Rustoleum rust dissolver gel (phosphoric acid, I think. Listed on the back that it would work on aluminium). Did not dent it. But, do I really need to remove? BTW, the rust stains are from the fasteners.
OccupantRJ
Eastern North Carolina
I use a blast cabinet and follow with a few coats of spray can clear on items of that nature. It ends up with a wet primer color look. I use the method as a customized finish. The bracket in the picture with the four bolts was done this way.IMG_3847.png
J
jives
Central NY
Okay, so no blasting cabinet, agree on the no-go for strong acid, and using a wire wheel on all the crevices. . . uggh, no, does not look like an effective use of time.
Internet shows a bunch of chemicals. Aluma brite, vinegar, etc. Anyone with good experience with them or something else?
Bigblue&Goldie
Drop them off at the powdercoater; they will likely blast them at no extra cost as part of prep to powdercoat.
Shiftless
East Bay SFO
Around here, the cost of prepping and powder coating a pair of ladder racks would be about the cost of a new set which seems to be about $600 after tax.
Steve from Socal
Hutchinson Ks.
Aluma-brite IS hydrofluoric based. It may work to some degree but the parts would need to be submerged not just spray on surfaces. If you use this then the rinse bath should have baking soda to neutralize the acid etch. It is worth a try if you have no other good options, a series of baths may be the best route?
