83trekker
I have a 23 x 26’ garage, 10ft walls 12 foot ceiling. I have radiant heating in the slab.
I have around est 680ft of ¾ pex w/oxygen barrier tubing.
2 loops , each loop is 340ft ea.
Ran 6” OC from the walls, 12” OC for the runs.
No insulation under the pad just packed sand/gravel.
Its is running off of a BTU Input 75,100--BTU Output 60,080---- 70 gallon Apollo Hydro heat hot water tank that’s made to work with in floor heat. I know this is a very large hot water tank but its worth close to $1700-2000 and I got it for 100 bucks brand new cause it has a dent on the bottom of it. So I couldn’t turn it down. This is a closed loop set up.
The help I need is what size pump especially with ¾ tubing and what size of exspansion tank should I use. All the plumbers I talk to say just goto your local store and pick up a pump and exp tank. These don’t seem necessary to size these up, yet I read about that it should be sized up and its very important. Any prof plumbers or radiant people on here? I talk to one radiant company and once they heard I was using a closed loop with a water heater and not the $5000 boiler system they said I should use didn’t want to help me any more.
So what do yall think?
