Can someone help me identify this tool!
Dangie
Attached
It is about 6” long. With GREENLEE imbossed on the handle. The swivel part has threads and looks like it takes a 5/8” or 3/4” bolt.
Thanks for your help!
D
Dangie
Attached
Can you or someone else help identify the tool on the attached photos?
Thanks
D
Dangie
Attached
Good guess , thanks. Anyone else ever use this tool and know what it’s use is ?
Thanks,
steaks&anvils
Colorado
That looks maybe like some kind of spud wrench/key, for utilities. Hydrants. Drains. Water main. Gas. Etc. Perhaps. Buckeye Mfg made jacks, also wrenches.
When You google "vintage Buckeye tools" and turn on the image view, a few of these show up. Also many with other "ends" too.
A quick look seems to point to a stove tool? Lots of farm implements made by Buckeye too. Some crazy stuff was used years ago!
D
Dangie
Attached
Can someone help me identify this tool. It probably dates back to at least the 1940’s in my family. The only marking is E.M.R. Industries College Point N.Y
Harry Oh
western ohio
I think on the t-handled tool you should be searching Buckeye Oil Equipment, Dayton Ohio. Back in the 50's thru the 80's I use to help install underground gasoline and diesel tanks for farmers and usually used what was called a flush fill box on those tanks. As Lugz said that tool was used on the flush plug on that fitting. I can't find a picture of a buckeye fitting but there are several with a similar brass 2 inch plug that sealed with an o-ring and had a different style of notch cast in the plug. The buckeye plug had just a rectangular notch roughly 5/8"x1 1/4" that your handle fit. Gary 20220415_005259.jpg20220415_005910.jpgex
