Can subpanel feed and branch circuits be in same conduit?
malibu101
Walnutport PA
Adding a subpanel next to the main panel to gain some extra breaker spaces.
Would like to run 1 conduit between the panels to take the subpanel feed wires AND the wires for 2 120V/20A single pole branch circuits through this conduit.
Is this code legal? Or must the subpanel feed and branch circuits be in separate conduits?
Conduit fill will not be a problem. Conduit will be plenty big enough.
Bert_
NW Iowa
Absolutely OK for a feeder. If this were a service then you could not.
mm08822
There is more to it than how many conductors can fit in a conduit even with 40% fill observed.
The conductor count in the conduit will cause a derating of all conductor ampacities above 3. 4-6 =80%. 7-9 =70%. 10-20 = 50%.
Better to move the home runs from the main panel into the sub panel and completely eliminate any branch ckts from the feeder conduit.
pattenp
Virginia - USA
If the new panel is next to the existing panel and the connecting conduit/****** is less than 24 inches in length the fill rate can be 60% and conductor derating does not apply. See NEC Chapter 9 Table 1, Note 4.
malibu101
Walnutport PA
The length of conduit is about 10" so it sounds good.
Thanks for the NEC section citation!
mm08822
Not an exception I typically use b/c of the lack of need. None the less - you're right.
