The big myth with bypass tubes is that you are magically "getting rid of the ballast". You're not.
All bypass tubes have a ballast, which is now called a driver. It performs the same functions as the ballast, with the exception of providing a starting voltage.
In the case of the LED bypass tube, you need to miniaturize the driver so that it fits in the 1" diameter tube. Engineering compromises have to be made to accomplish this. One of those compromises is heat sensitivity, which is why drivers are still the weak link in any LED system. The tiny driver is then stuffed into the tube where all the diodes are busy creating light and heat. And then an end cap is put onto the tube.
Basically what you've done is taken a heat sensitive driver and stuffed it into an oven.
Fortunately, LED tube technology has gotten better recently and the diodes dont run as hot as they used to, so this is becoming less of a problem. BUT...that's only necessarily true with the name brand manufacturers. When you buy LED tubes from Amazon, Ebay, etc....I'd argue that not only are you NOT getting rid of ballasts, you are actually making the situation worse.
As much as a pain that ballasts can be, they do provide some benefits, which is why the ballast-ready LED tubes have grown so much in popularity. They have some degree of surge protection built into them. They are much better at current regulation, which the diodes need. The heat-generating power conversion process necessary to run LED tubes is done in the large black can that is attached to the fixture, so the heat sink is huge. Ballast-ready tubes also react to the ballast factor, which can assure that the proper amount of light is delivered.
Ballast ready tubes, in general, create about 2 watts of ballast losses per tube. If you have a 14w tube, then it will actually consume 16 watts. This varies some, due to electronic weirdness. Also, the ballast will run significantly cooler when running LED tubes because the load is reduced by approximately 50%. Running cooler helps extend the life of ballasts.
You often hear that bypass tubes are more efficient than ballast-ready tubes. If you were comparing two lamps, both 14w and with equal lighting performance, then this would be true because the ballast-ready tube would use 2 extra watts of ballast losses. However, as a general statement, this isn't true. Ballast-ready lamps often need to use fewer watts, ballast losses included, to achieve the same lumen output.
Using the example above, if we had a 14w bypass tube and a 10w ballast-ready tube, the ballast-ready tube would be more efficient, provided they both delivered the same lumens.
Hope this helps clarify a few things.
CD
