Can this fan motor be saved?
Rod N
Keswick, Ontario
This the fan motor for the bathroom at work and it squeals like a banshee. It's a 40 year old (guessing) unit that is hard wired and the box is built into the ceiling. It would be the easiest to buy a new fan with housing, but the install would be a pain and it's not like I have my tools at work. Be great to buy a new one, but where?
Would oiling it bring it back to life? I think it has bushings as opposed to bearings. The blade is pressed on so I can't get close to it.
engineer2
Chicago burbs
I've oiled them before. Simple to try. If it doesn't work, off to the store.
I agree about not trying to remove the fan blade. It will probably crumble.
You can buy a new Broan "noise maker" 50 CFM fart fan for $25.
nadogail
Coronado, CA
You might clean and oil your old motor and get a few more years of service out of it; or it could be a exercise in futility.
You put in our effort and take your chances.
Bert_
NW Iowa
If you catch it early oiling it can make it last. It's just a generic c frame motor, I have replaced lots in bath fans and similar stuff
dogdog
those are called shaded pole motors I think. Size should be standard by the size of the shaft and the motor body even if it is 40 years ago... The area that usually failed are the front and back bearings when the grease are dried up or hardened due to age or dust. I have some success cleaning up the bearings and re-grease with a light weight oil. Usually there is a felt washer or wig to absorb/retail oil.. and most are bronze sleeve bearings... well it's good up to a point until the swell and or crude up and burns the coils ..
anyways yes you might get a few years out of it.
Chance
New England
I've cleaned the bearings/bushings on many an old bathroom fan and put them back in service. (The original fans move more air than the replacement ones). If I only use oil it lasts 2-4 years before the noise comes back. Then I started using grease and that lasts maybe 4-8 years.
For my 24" box fan and a 30" drum fan, oil was about 2 years and grease 4-6 years before the noise comes back. The latter are higher wattage and run hotter and tend to get attended to as soon as the noise starts since they are easier to get to.
My oldest box fan, from the 60's, is incredibly heavy. Its motor has a tiny metal capillary tube that leads to the bearing/bushing. So it gets one drop of oil each season when it gets put to use. A shame they stopped putting those on electric motors.
American Locomotive
Rhode Island
Just take the screws for the bearing brackets off, and the whole motor will come apart. Drop some Zoom Spout (or 3-in-1) oil into the bearing cavity areas, and it should be good to go for another few years. Most of them have little felt pads in the bearing/bushing areas, and they'll hold a decent amount of oil for a while.
American Locomotive
Rhode Island
The felt pad runs out of oil after a while, and then the shaft will start skidding on the bushing. Oil the pad with 3-in-1 or Zoom Spout, and then liberally oil the shaft. If the shaft or bushing isn't too damaged, it should come good.
Drill Sergeant Arc
Ore-gun
In our area there is a company that sells and repairs electric motors. I bought one for a fan swap and it’s been going for over a decade. You may pay more but you will get the right one if you take the old one when you go in. There’s a company like that in every industrialized city. I like to buy local and support the small businesses. I even bought a furnace inducer motor for my Lennox from them and it was $160 vs like 300+ from the dealers or online.
