Can this switch be used as a inline simple switch
Notgrownup
Snow Hill NC
I have this switch I just want to put an inline switch to operate a LED light . I know I can go get a simple 2 screw switch and cut the hot and wire it but I’m wondering if I can use this one laying around
Gozo
Central VA
Sure. It’s a SPDT switch, like used to control a single light via 2 switches. Just use the center pole and one of the throws. You might wind up with down as on and up as off. Just swap the throw if that’s the case.
mm08822
Technically, no b/c it's supposed to be labeled on/off. ( yes I know 3way and 4 way switches aren't/can't be labeled.)
mm08822
What about decora switches? I may have used a three way or fifty in place of a single pole in the past.
Good point, decoras make for the same problem. I'd have to see if that requirement got dropped or exceptions made.
N
Notgrownup
Snow Hill NC
Ok , never mind, I went and bought a simple 2 screw on off in line switch. $.98 so I bought a spare . Lol . I needed an excuse to go spend time in Lowe’s. Can’t believe I walked out of there for less than $5 and had 2 switches, a cover plate and a receptacle.
i will keep this one in case i need it later. Thanks yall
mm08822
got a code on that? what about decora switches ?
I'll search for it. It's been a while since I heard that banter.
ETA:
NEC 404.7 (Note: yoke style switches have moved from section 404 to 406 (and renamed wiring devices) in the 2026 nec.)
