oldschoolcraft
Eventually I'll build out a huge collection of tools but want to focus on the core needs first.
So one idea I had: if I bought a set of Universal Flex Deep Sockets (like the kind SO makes), can those be used in place of a regular deep socket?
I understand the universal sockets are a bit longer, so you may run into a clearance issue, but in that case, I could probably use a box end wrench.
And in cases where you need a universal joint socket, you really need one, and nothing else will do, right?
So for a bare minimum, could you get away with just having shallow and
"universal deep" as your two sets of sockets, with a box end wrench to cover clearance issues?
Or are you better off with a shallow and deep regular set, and a single universal adapter to add on as needed?
Assume that price of the more expensive universal sockets isn't a factor, and assume you had to choose. You can't have shallow, deep, and universal sets. Specifically referring to non-impact, chrome sockets here.
I'm not a pro and it's okay if it takes double or triple the time to do something. But I hate running into a situation where I shrug and just simply can't do it at all. That's why I'm leaning towards the universal socket set, but maybe I'm wrong.
Edit: my new idea is to use blue painters tape around a deep universal temporarily if I need a deep 1/4 socket. Otherwise if it’s just a clearance issue that doesn’t require a deep socket I’ll use my regular shallow socket plus extension as I have been doing all along.
