Can You ID This Old Wayne Compressor
Bryan Bridges
Salem Oregon
I just got this old Wayne compressor to restore in my middle school shop program. (I love old tools and restoring them). I have searched high and low on the web and can't for the life of me find anything on this compressor pump. The motor is a 1915 Century, 3/4 HP, 110/220 Volt, single phase RSIR motor. It is just massive for a 3/4 HP (11-12" in diameter). The tank on the compressor is something like a 50-60 gallon at least, supported by cast iron saddle/legs. There is a massive cast iron plate/bed that the compressor pump and motor rest on that bolts to the top of the legs. The bed has a brass plate with "Wayne Serial # 129347 on it. The tank itself has a brass plate brazed onto it, but I didn't remember to write that number down. If it's important, I'll take a photo of it and post that later.
It has a sled motor adjustment to tighten the v-belts from the motor to the flywheel. Everything on it says Wayne, even the pressure gage. The pump, however, only says "Junior" number 31054. It's a "Two Stage" pump, (that's cast into the pump as well on its front). There isn't a patten number but it has "patten pending" in back of the pump's casting along with "1X0143" on the bottom rear casting of the pump, just below the flywheel shaft.
It pumps up, the pressure gage reads pressure, the motor fires up just fine. I didn't run it to anything above 50 psi because I didn't know if the gage was accurate or if the pressure switch was functioning. I just know it sounds nice and quiet with no knocks and looks sooooo cool. It is currently all in parts awaiting cleaning/paint removal and then a new coat of primer and paint. I'll also replace all the fittings/tubing and old wiring. I know I should have the tank tested and plan on doing that. Then, I'll put it all back together with the kids and use it until I retire. Then it will go into my retirement man cave with the other great vintage tools.
The only issue I can see is that the flywheel is a little out of round by about 1/4 inch. It has a slight hop. The guy I bought it from took it in on trade and told me the previous owner used it daily to run his whole shop. I hope it will prove to be a good risk at $200.00 (what I paid for it).
I've attached some pictures so you can see it and if anyone can help, it would mean so much to me and my students.
I've posted this same thread on the general board as well. Sorry for the duplication.
Thanks so much,
Bryan Bridges
Leslie Middle School
Salem Oregon
The plate you didn't copy down probably has all the spec's on the tank (test and use pressures, date made, etc... Useful stuff)
That has to be one of the coolest old compressors I've ever seen. Looks to be a two stage too! Great find!
Bryan Bridges
Salem Oregon
I agree, very cool. The plate on the tank just had a serial number and no other information.
Here is a photo of its current state in my school shop. I'll post better pictures soon to show more detail and the process as it moves along.
Bryan Bridges
Salem Oregon
Measured the tank today (14" diameter and 48" long) formula is radius squared times pi times height of tank times 0.00432900431. This ended up revealing that the tank is only a 30 gallon size. Man was I off in my estimate! The compressor is the right size for my needs and I look forward to getting it all stripped down, primed and repainted a great color with new brass and copper wherever I can put it. I'll run it 110 volts until it is hard wired and plumbed into the garage of our home we are going to retire into in Ashland Oregon. The pump and motor are the coolest.
Still trying to find out more about the compressor such as its age, CFM and whatever else I can uncover. Any help will be so appreciated.
Bryan
Bryan Bridges
Salem Oregon
Here are some photos of the Wayne I've been restoring.
She pumped up to 150 psi in about 17-19 minutes in the 30 gal tank. Held pressure all night long. Chugs right along.
I've made an oak belt cover for it and put some big casters on it to roll it around. I'll take photos when it is all done and post a new thread.
Bryan in Salem with the kids in shop at Leslie Middle school
