Can you identify these tools?
Bricago
Chicago
I bought some tools on CL, mostly craftsman =v= series wrenches, ratchets, and sockets, and these three pieces were included.
1. Round metal rod 8" long, 3/8" diameter, with a small semicircular bearing on one end.
2. L-shaped square cross-section metal piece. 3.5" x 2" bent just beyond 90 degrees.
3. Tool marked "Kar-Tools 269"
Thanks for your help with what these are.
Zeke
First one appears to be a cross bar for a large socket extension like 3/4". Second one I have seen at some point but don't know other than It appears to be missing an end.
So, how is that drum brake tool used?
Gmonkee
The first is a crossbar for a breaker bar, the 2nd is a wrench to tighten up a piston ring compressor. The 3rd is indeed for use on drum brakes.
jim1987
Its for the retainer clips.
Handyfarmer
in the high plains of Colorado
the brake tool
on brake drums there is a spring that holds the shoe in place, there is a pin with a nub on it that goes through the backing plate and then a small coil spring is put on and then a clip or holder/retainer that has a slot in the center that will fit over the pin and a quarter turn and It locks the retainer on, the tool allows one to push on the retainer, and then turn the retainer either removing or putting it on,
http://www.billswebspace.com/TJDrum.htm picture 17 show it being used,
a picture of the retainer and spring and pin, http://www.firebird67.com/images/brakes28.jpg
and I agree with the sliding t bar handle as possibility
http://assets.suredone.com/1742/med...-socket-wrench-1-2-sq-drive-10-long-usa-5.jpg
it is possible it could be a flaring tool handle
http://www.mytoolstore.com/sk/90443a.jpg
or any small tool that could use a sliding handle even a tap wrench,
http://www.irwin.com/uploads/products/large/two-in-one-tap-wrenches-939.jpg
and the spring compressor wrench,
http://www.parkinplant.com/images/piston ring compressor.jpg
It is possible it could be a key for some thing else, but if is not for a piston ring compressor,
depending on size it would be a key or wrench for square headed drain plugs,
Plombob
Tennessee
The first one is a pin handle. It fit into the handle of breaker bars, extensions and sockets back in the day. It has a ball on one end to keep it from sliding out of the hole in the other tool.
woody 73
The Great State Up North
Sliding bar (no longer made they came in different sizes for your craftsman tools 1/4,3/8 1/2 etc.).
Ring compression tool see bluebolt's #6
Brake tool
You guys are fast...
rlitman
Long Island
the brake tool
Yep. That second picture shows the retainer off the pin. You would rotate it so that the oblong hole in the center (not visible) fits over the squished end of the pin. The push the retainer down with the tool, and rotate the tool to rotate the retainer 90 degrees so that when you let go, the pin will not come out of the hole. The ribs inside the tool catch on the retainer to help it grab and rotate.
