It defiantly got hot. The PC board was charred. Everything just died. I read somewhere that this type of resistor could be used as a fuse! I was looking for a blown fuse when I found it by using a light behind the board.... Are you sure it is bad ? The resistor really doesnt look like it got hot.
You sure about that?I have done that but I did it again, only this time I set my meter right. It read 0.8 ohms.
nah, Georg is the most appropriate first name for a resistor.Can you name this resistor?
Bob. I name that resistor Bob, What do I get?
Yes.It defiantly got hot.
There's no need to be name calling.Judging by the color, the only appropriate name would be oompaloompah.
which is why schematics are so importantIt's quite clear the middle two are different colors, and reading left to right, #3 is darker than #2. #4 looks to have some remnants of shininess, and so appears to be a gold tolerance band. There's another nearby green resistor with a gold band as well.
So from left to right, my guess is:
Dirty white (or maybe yellow?)
Red
Brown
Gold
So that's, uh, erm...
9
2
x10Ω
920Ω +-5%
Resistor Calculator
This resistor calculator converts the ohm value and tolerance based on resistor color codes and determines the resistances of resistors in parallel or series.www.calculator.net
I have no idea whether that actually makes sense or is an actual component one can buy, mind you.
But #3 could be an overheated orange, perhaps? Basically, #2 and #3 could be red, orange, brown, or maybe even violet depending on what you think the effects of overheating and age might have been.
Personally, I'd try to wipe off some of the grunge with WD-40 or alcohol or similar and get some good strong incandescent (full spectrum; not LED) lighting in there. If that doesn't bring any enlightenment, maybe try scraping or lightly polishing or sanding part of it. The paint is not very thick, but it you can abrade the top layer of grunge off, you might get somewhere.
Or is this just an academic exercise? That board looks to be in pretty rotten shape overall.
Resistor color codes were just a rotten idea from the beginning, and are one of those maddening little archaisms that's still hanging around. Differences in human color perception can be very pronounced (even in person and not altered by a camera and computer screen). Diagnosable color blindness is fairly frequent, and pretty much everyone perceives color differently to greater or lesser degrees.
Stir in manufacturer variations in paint color, thickness, and application, not to mention the wildly varying effects of age, dirt, and heat, and you've got a ridiculous mess of mysteries.
Don't think you mean latterly - look it up. You probably mean literally but why do people even use that word - just say it exploded. The word is overused.I have decided to buy a new garage door opener. I think the blown resistor is just a symptom and not he cause.
The following took place over a month or so...
The GD would reverse while closing, intermittently. I cleaned the sensors, no joy. I replaced the the sensors, no joy. I replaced the motor capacitor because the motor did not start and hummed at one point and to only thing to stop it was to un plug the unit. The replacement capacitor lasted a few weeks. It was a cheap one with the right specs, but, it latterly exploded after a few rapid open/close test, leaving a plastic like gunk on the PC board. The motor also seems to over heat.
The system completely died after the sensors were changed out. I tested the change out with three open/close cycles and it worked. Then while leaving it failed to close. I had to make three or four stop/close attempts for it to stay closed. Upon returning and attempting to close, it reverse. Playing with the wall button the motor stopped and hummed again and I had to unplug the unit. I got it to close, but then noticed the sensor LEDs were not on, The whole system was dead. I tried different outlets and devices to confirm that power was going to the unit.
Then I found the blown resistor...
The use of the word “literally” never bothered me, till it started getting used literally in the opposite way of the literal definition of the word “literally”Don't think you mean latterly - look it up. You probably mean literally but why do people even use that word - just say it exploded. The word is overused.
Since you have so many issues I think replacement of the whole opener is the right choice.
At first I thought you meant laterally, but wondered why the direction of the explosion was noted.Well
At 76, latterly might work, but, literally was what I meant. Damn spell check!
At first I thought you meant laterally, but wondered why the direction of the explosion was noted.![]()
That's it. Not exact, but close enough. My board dose not have the little blue adjustment thing in the first pic, but it does have the holes on the PC board where it goes. And my board has six terminal screws (not 3).Is this it? Possibly green/purple/brown/gold?
Guess I should have added this to the original post. The upper right resistor is the original.
Now my brain is starting to hurt!
