Can you recommend an inexpensive trailer jack?
wahoowad
I need a swing back trailer jack for a small trailer, 1000 lb. rated would be fine. I don’t want one with a wheel, instead I want a flat foot. I can’t seem to find one with a flat foot that will bolt to a trailer. Instead all I can find require welding and I don’t want to do that.
Even the Harbor Freight one needs welding. Any suggestions for a budget model that swings back and bolts on?
GypsyR
upstate SC, USA
If you can compromise on having a wheel, you can get one at Tractor Supply for $40, easy.
Sportsman Series 1000 lb. Trailer Jack
SKU # 124810399
But being a bolt-on and wanting a pad makes it tougher in the bargain department. You can put one together for about $65 though.
Bulldog Bolt-On Swivel Trailer Jack
SKU # 116165599 and add a fixed foot Bulldog Jack Base Plate Kit
SKU # 184001399
(If I posted more I could provide direct links)
mike93lx
Richmond, VA
Check etrailer. Selection and pricing is quite good.
I have had great luck with Bulldog Jack's. Not the cheapest, but they last
YukonXL04
Arlington, TX
HoosierMark
Southeast IN
Harbor Freight has them and they bolt on but they do have wheels You could simply remove the bolt from the wheel and insert a foot in the space. I just bought two of them for $22 +/-. I used them with a 2 x 6 attached to a scaffold on rough ground. I just bolted them to the 8 foot board and then bolted the other end to the scaffold. It allowed me to level the scaffold easily and move it as needed. I have a couple more on small trailers and they just bolted on easily.
