Can you thread 16ga material?
gtivr4
Vermont
Is it possible to run threads in 16ga material to run a bolt into? I'm designing an item that doesn't need to be overly strong, but I need to be able to run some bolts into some thinner tubing...
if 16ga is too thing (for sat a 1/4-20 bolt), what would the minimum gauge be? Is there a way to determine appropriate material thickness to thread size?
Zengineer
British Columbia, Canada
Nutserts are your friend... because the answer to 16ga and a 1/4-20 bolt is no.
They basically install like a pop-rivet. Aircraft spruce, Pegasus auto racing, Mcmaster, etc. carry them.
PAToyota
South Central Pennsylvania, USA
16ga is about 1/16" thick. At 20 threads per inch you're barely going to get over one full thread in that thickness. I'd want at least two or three threads minimum. 11ga would be 1/8" and get you 2.5 threads, which would be about the minimum for me.
brownfoot
NC
the distance between threads for a 20 lead (20 threads per inch) is .050 inches which means less than one thread for 16 ga, which will hold enough to keep the screw from falling out, but that is about it.........
normally the thickness should be the diameter of the thread, or for a rule of thumb, look at the thickness of a standard nut for the size of screw or bolt
djjsr
In the cornfields
You could try a smaller bolt if it doesn't need to be 1/4". I just threaded some 16 ga. for 10-32 screws and it worked just fine.
DocsMachine
Flow Drilling is an option. It essentially forms it's own collar in the workpiece, which can then be threaded. Works in a normal drill press, although you need a somewhat beefy one.
Doc.
MrMark
Southern Cal.
Isn't there a punch that "rolls" the material inward to essentially do what the "flow drilling" is doing?
rsanter
visalia ca
you can drill a smaller hole
put a socket on the back side
and use a punch or drift to roll the material into the hole
now thread this hole and you may be good
do a test piece first so you will learn the hole size to use and punch size
whats wrong with a nut on the backside? you could weld the nut on to be perminant
bob
e-tek
Saskatoon, SK
That's a hell of an answer! I had to write it down...:thumbup:
Daniel Dudley
You would use a #14 tapping screw with a hex head. That is a quarter inch screw, and made for sheet metal.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
You can thread 16 gauge and it will work, but the better way is to extrude the hole so you have more to work with. By that I mean you start out with a small pilot hole, then drive through the appropriate size punch to bring up the hole diameter to the appropriate size tap, then thread accordingly.
nkachur
Manitoba Canada
bob
That is a great idea... wil have to remember that
