Sonorous
Someone buy these so I won't! There was a third kit but I don't see it anymore...
Online at BC Fasteners & Tools (free shipping with orders over $150).
The first kit is the better deal IMO, with 4.0 ah batteries and the (brushed) active response drill. I'm really tempted to buy this but I'm already deep into Makita 18v and still supporting legacy dewalt 18v for some specialty tools (not to mention m12
They also have single 4.0 ah batteries for for $49.
$199 - Bosch CLPK224-181 18V Hammer Drill & Impact Driver Kit
Includes:
1 - Bosch HDH181X 18V Brute Tough 1/2″ Drill Driver w/ Active Response Technology
1 - Bosch IDH182 18V EC Brushless Socket Ready Impact
2 – 18V Lithium-Ion 4.0Ah FatPack Batteries
1 – Charger
1 – Carrying Bag
Anti-Kickback Active Response Technology with smart acceleration sensors reduces the risk injury to user wrists or arms cause by reactive torques in bind up/jam situations
4-Pole Open Frame motor delivers more power in a smaller size
Optional Flexible Power System (FPS) for a choice of maximum run time or minimum weight
Comfortable ergonomic design
Durashield housing withstands jobsite use and abuse
Integrated LED job light
Comfortable soft-grip wrapped housing
Variable speed trigger for maximum operator control
Electronic Motor Protection (EMP™) protects motor in heavy duty applications.
Voltage: 18V
Chuck size and type: 1/2″ Keyless
Clutch settings: 25+1
No load blows per minute: 0 to 27,000 BPM
No load speed ranges: 0 to 440 RPM and 0 to 1,850 RPM
Torque: 752 in-lbs
Height: 8″
Length: 8.9″
Weight: 5.0 lbs
Warranty: Limited 1 year (3 year with ProVantage)
All-in-one Impact Driver and Impact Wrench with a 1/4″ quick-change hex and 1/2″ square drive chuck for sockets
Choose between 3 speed and torque settings to maximize power or minimize fastener damage
Best-in-class torque at 1,650 in-lbs
Integrated 3 LED work lights maximize illumination without shadows
Brushless motor delivers up to 2X the motor life and greater efficiency for longer runtime and less maintenance
Advanced electronics help prevent overloading and overheating for longer tool life and extended runtime
Bosch Lithium-ion batteries deliver up to 50% more runtime, cold weather performance in -4° temps, and fuel gauge
Bosch Advanced Lithium-ion Technology optimizes performance through Electronic Cell Protection (ECP™), Unique Pack Design which keeps the battery cooler, and Electronic Motor Protection (EMP™) which protects motor in heavy duty applications
Battery voltage and chemistry: 18V Lithium-Ion
Drive: 1/4″ Hex Drive and 1/2″ Square Drive
No load Blow Per Minute ranges: 0 to 3,200 BPM / 0 to 2,600 BPM / 0 to 1,100 BPM
No load speed ranges: 0 to 2,800 RPM / 0 to 2,000 RPM / 0 to 1,300 RPM
Torque ranges: 0 to 1,650 in-lbs / 0 to 900 in-lbs / 0 to 400 in-lbs
Height: 9″
Length: 6.2″
Weight: 3.2 lbs
$199 - Bosch CLPK250-181L 18V 2-Tool EC Brushless L-Boxx Kit
Includes:
1 - Bosch HDS182 18V EC Brushless Compact Tough Hammer Drill Driver
2 – 18V 2.0Ah Lithium-Ion SlimPack Batteries
1 – Charger
1 – L-BOXX2 Storage Case
2 – Exact Fit Insert Trays (for L-BOXX2)
1 – 4X Bit tip holder
1 – 4 Piece bit tip set
1 – Magnetic bit tip holder
1 – Double ended impact bit
2 – Belt clips
Most compact head length in its class for easier control in tight spaces
Flexible Power System (FPS) means the HDS182 runs on all Bosch 18V Li-Ion batteries
Brushless design delivers superior power in a compact head for great performance and easy control in tight spaces
Clutch settings: 18+1
No load Blows Per Minute range: 0 to 25,500 BPM
No load speed ranges: 0 to 500 RPM and 0 to 1,700 RPM
Torque: 442 in-lbs
Height: 7.75″
Length: 7.44″
Weight: 3.75 lbs
Height: 9″
Length: 6.2″
Weight: 3.2 lbs
). They also have single 4.0 ah batteries for for $49.
Includes:
1 – Charger
1 – Carrying Bag
Voltage: 18V
Torque: 752 in-lbs
Height: 8″
Length: 8.9″
Weight: 5.0 lbs
Height: 9″
Length: 6.2″
Weight: 3.2 lbs
Includes:
1 – Charger
2 – Belt clips
Torque: 442 in-lbs
Height: 7.75″
Length: 7.44″
Weight: 3.75 lbs
Height: 9″
Length: 6.2″
Weight: 3.2 lbs
