It's a mix of MAPP and Propane (MAPP - Pro). Propane burns at a temperature a little below 2000 C, Mapp-Pro bumps it up a little (to like 2050). The old map was more like 2500 or higher if mixed with oxygen.I had no idea MAPP was discontinued. I've never used or needed it, even on my rust belt Subaru ball joints. But I keep hearing people referring to MAPP for high heat, so what are they referring to if it's discontinued and not this?
I've heard discussion that maybe Mapp-Pro is better than it sounds because of some heat-transfer quality, but I'm not qualified to speak about that. You can also mix oxygen with propane to increase it's temperature, so I suppose it all depends on what you're aiming to do.
I still use MAPP Pro occasionally, when I get a good price, but it also depends on whether you have a high-heat torch or a pencil flame.
