Canadian tire tap and die set
e-tek
Saskatoon, SK
I have it and have used it for years - only broke one (small one). Treat them with care i.e. don't over torque them.
I now (also) have their major, titanium coated set. Awesome value when on sale!
ADSR
For 27 bucks, sure... the taps are fragile.
I disagree. Ive had this set for almost 10 years. Its been very solid. Mine is old tho. Maybe the new ones are made differently.
aptdweller
Ottawa, ON
I have a few of these sets (both the old uncoated versions and new "TiN" coated) and I've never seen one fail by wear. They work fine when used gently, but break pretty quick when abused.
For $27, they're not a bad deal.
Jswain
Calgary, AB
If you need just one tap right now buy a single and hold off for that set because it goes down to 39.99. However if you need a full set right now then yes it is worth every penny and more I have used mine a lot and have only broke two taps and have returned then no questions asked
D
dillymann
Newmarket Ontario, Canada
Ok thanks, I will hold off for now then.
Sent from my iPod touch using Tapatalk
Advan
Ontario, Canada
Definately home-owner grade stuff, but if you really need an assortment on hand, why not? I agree with a previous poster, if you only need one tap here and there, buy them from an industrial supplier, and get a good handle too, you'll be much happier.
katy
Check the wording on the "Lifetime warranty", some of CTs don't cover breakage, only "defects".
D
dillymann
What would be a better set to get, I do alot of small engine work from home, im not a certified small engine mechanic but thats what im going to be after I graduate high school
MikeF2316
Thornhill, ON
The handle for taps isn't as strong as it needs to be...
