Canadian tire torque wrenches?
14skawt
Unfortunately, I don't have any experience with the ctire beam wrench. I have had the 1/2" drive click type for about 15 years, it works fine. Out of curiosity, I brought it to work and checked it on the transducer and it was still accurate on the settings I use frequently.
rmsg0040
Toronto
I have a 1/2 one, its good. It came with a lifetime warranty when I bought it. The ratcheting mechanism broke, walked in with the old and walked out with a new one.
Looking online it looks like the new ones only come with a 1 year warranty.
I like my split beam torque wrench more, easier to dial in whatever torque and no need to dial down when done.
matthew
I have a 1/2" drive Maximum, which I just used today. Mine is the previous rubber handle version - the current ones have a metal handle. My brother has one of the current ones.
I think they're decent, they'll do the job for a weekend warrior. When you can get them on sale for around $60 they're rather good value. But not perfect.
- the older ones had 10 ft.lbs. per turn of the handle, the newer ones are 20. I find the older ones easier to adjust.
- I do sort of prefer the newer all metal construction, as the older ones the ring on the handle with the reading on it was plastic.
- For me I wish they offered a few more models with different torque ranges. The 1/2" drive 250 ft.lbs. is great, but a 150 ft.lb. model would be nice so that lugnuts are right in the middle of the range for accuracy. And because it's such a high torque range, it's quite long and can be a bit awkward. Likewise, 240 in.lb. with the 3/8" drive version is a bit low - I also want something with 40-50 ft.lbs. capacity range.
I haven't looked much at the regular Mastercraft (not the Maximum) models, but I would consider them, I'm sure they're at functional. The Stanley models are probably fine, too, but looked like plastic in the handles and I don't see any point in buying them over the Mastercraft or Maximum models.
I do think they're significantly better than the cheaper Princess Auto torque wrenches, although I can't really say why.
The flexible beam style works and are inexpensive, but ratcheting clicker style is better, particularly in confined spaces.
patchap
PA torque wrenchs work fine, I tested my 5 or so year old 150lb ft clicker against a buddies snap on before I did some important stuff. Was within a couple lbs.
I used to have the 250 Lb ft maximum one, but I never went above 120lb anyway so I got the small one.
I also like that the handle locks, so if your bearing down it won't spin a bit.
