Canarm Ceiling Fan Controller
LivenLife
Oklahoma
I had 2x CP56HPWP 56in Canarm Fans installed in the shop. They are wired into a single Canarm variable speed switch w/ reverse. On minimum speed, they are still turning to fast. The manual says there is a minimum speed adjustment screw. Can someone help me out and tell me where this screw is located? I would appreciate any help.
L
LivenLife
Oklahoma
Sorry guys. Just noticed I put this in the wrong forum. I was able to come home and locate the adjustment screw and got them turning slower.
Bert_
NW Iowa
You can set the minimum speed screw pretty low. You just need to make sure the fans don't stall with the main speed knob on low. If they stall it can burn out the motor.
