How do you figure out the length of a right angle triangle if you already know the two dimensions that are the same? Say you want to build a shelf in the corner wall. You went 24" out from the corner on both sides. How do you figure out the other dimension? I can find the calculator but how do you figure it out? So I can do it on my calculator.
while that is a handy calculator, it is much simpler in this case than the trig there is.
with right triangles, its A(squared) + B(squared) = C(squared)
A and B are the distances you already knew, so it would be 24(squared) + 24(squared) = C(squared).
So [ (24)*(24) ] + [ (24)*(24) ] = C(squared)
In this case, you can do (24*24), and multiply that by two.
With the answer you get, use the square root function on your calculator, and that is the length of the hypotenuse (the length you don't know)
