Can't get a snap on ratchet apart
Case
So i have a S831 snap on ratchet I decided I want to clean it and lube it since it sounds pretty dry inside. I took the 2 t15 screws out and can't get the cover plate off I have tried slapping it against the bench putting it in a vise and jerking it up and down no luck what soever :dunno::mad: advice ?
spongerich
Monroe, NY
I might be talking out my *** (wouldn't be the first time) but aren't those sealed? Or am I thinking of the S80's?? Do you have an arbor press? That'll get her apart, but you might damage it in the process.
DrkMtnDew
thread the screws back in 2-3 turns and give them some light taps.
lauver
Belton, TX
Case,
I'm not familier with the S831 ratchet. Can you supply a couple of photos of the top and bottom of the ratchet head?
I'm guessing your cover plate is rusted or corroded to the ratchet recess. You might try soaking the ratchet in a 50:50 solution of Acetone and Power Steering Fluid overnight. Then, in the morning, take a 90 degree (shaped like an "L") precision pick and stick it thru one of the screw holes in the coverplate and pull the plate off. That should do it for ya.
C
Case
don't have access to a camera at the moment sorry.
ill try the screw trick and soaking it already tried hitting it against something to get it apart didn't work.
otis66
Wrap a rag around the head of the ratchet and then tap the square drive on a wooden board. The rag should keep the guts from being lost.
wreckercologist
cyber-tool hell
i slap them gear down on the anvil a few times and the rusty ones come apart rather easy.
This^^^^^^
The 800's have an o-ring all the way around the cover plate and they can be pretty snug coming apart sometimes. Also, cleaning the o-ring groove and the o-ring before reassembling will help it going back together.
