I bought a six inch galvanized bracket from the hardware store to use to make a mounting bracket for a 12v usb/power receptacle for my truck. I have to drill three 1 1/8" holes to mount the sockets in. I bought the 2pc step bit set from hf to accomplish this job. Working slowly and feeding the bit only as fast as it woukd cut, it seemed like it was cutting well. Beautiful metal shavings were coming off the piece until I got to the 1" step. The shavings turned to chips and the bit failed to drill any further. I don't burn the bit, I used oil and slower drill speed on the press. Are these bits complete garbage or did I get a defective bit? Can you recommend a decent bit from home Depot if garbage is the case? I rarely drill metal so I don't need anything expensive.
