Capacitor interchange question
jboehm
Spring, Texas
I have a circulation pump for my hot tub that I suspect has a bad capacitor. It will not start on its own, but if I spin it by hand it goes. I can not find the exact replacement, but I can find one with what appears to be the same specs. Can I replace the rectanglular black one with the oval one. The original one is mounted in the tail cap, but I should be able to mount the oval one outside. How critical is to get one with the exact specs. Can I use one with more uf/mfd?
rlitman
Long Island
I don't see a temperature rating on the oval one, but otherwise it looks like a fine substitute.
exmaxima1
Midwest
wyliesdiesels
Modesto, CA
Ummm, all components have some tolerance. 5% on a run cap is very good, and pretty much says it's not an electrolytic type.
U misunderstood what i was saying.
The OP asked if the mfd on a replacement cap has to match the original.
And so i was replying to that...
J
jboehm
Spring, Texas
My recollection is for this setup it doesn't make a difference which wire goes to which tower. Is that correct?
rlitman
Long Island
That depends on the capacitor style, but in the case of AC metallized film capacitors (such as the oval one above), they are not polarized. The only consideration for these is that they need a little clearance room above the terminals when mounted. This is because the internal protection in the event of a fault is to have the terminal cap bulge a little (usually around 1/4"), which causes the terminals to disconnect from the film.
Electrolytic capacitors in DC service are rolled up in such a way that charging them with the correct polarity will tighten the winding, and charging them with the reverse polarity will try to make them unwind, which puts undue pressure on the case.
Alchymist
Central PA
Electrolytic capacitors usually have quite wide tolerance range for capacitance value - often up to -10% to + 50% of marked value, tho most will vary on the + side.
exmaxima1
Midwest
Putting reverse polarity on an electrolytic cap will also dissolve the anodized layer on the aluminum film and quickly short it out, boil the electrolyte, and "cause undue pressure" as well. I never knew about the winding tightening/loosening, and I appreciate that info. :beer:
rlitman
Long Island
:) Yeah, they're coiled like a clock spring. With high voltage electrolytic capacitors you're supposed to slowly ramp up the charge voltage for their first use. You can actually hear them strain as they're charged the first time.
exmaxima1
Midwest
I've ramped them up for years when I was building tube amplifiers. It was called "forming" and I thought I was re-anodizing the electrodes as the layer dissolves slightly over time with no potential on them. Interesting that there was a mechanical aspect to the procedure as well.
Alchymist
Central PA
A start capacitor can have a 10% variance on mfd(micro farad).
A run capacitor cannot have any variance...
Typical spec on run capacitor is +/- 6%, tighter than the start cap, but still allowable. I think where the confusion comes in is that the 6% is the allowable deviation FROM MARKED VALUE, not that you can substitute a cap that is 6% larger or smaller than the marked value.
Now if you could measure actual capacitance, you could search other caps of different values to find one within 6% of spec'ed value. Not many people have that capability.
J
jboehm
Spring, Texas
Well, cap is on and the motor starts and runs strong again. I guess I never noticed, but that motor sure runs hot.
wyliesdiesels
Modesto, CA
Exactly :+1:
Thats great u got it running.
Does it have a fan?
Do u have a clamp meter? If so measure the current that the motor is drawing. Is it close to the FLA listed on the nameplate???
rlitman
Long Island
Capacitor life can be inversely proportional to running temperature. Your cap may have failed because it was inside the case, and with the replacement being outside, it may last much longer.
exmaxima1
Midwest
Is the motor under load? It is normal for many capacitor-run motors to get hot (or even overheat) when run without the intended load on them.
J
jboehm
Spring, Texas
Yes, it is under load all of the time. Even the jet pump motors are hot when they are running.
