Air compressor worked fine a day or so ago. Today I go to use it and notice the tank pressure is low. Motor doesn't start when I use air. Checked breaker, its on and not tripped. Reset button on motor has tripped. When I pushed it in the motor tries to start but only rolls over slowly. Motor and compressor both roll over easily under normal pressure on the belt from my hand so nothing is dragging... Is there a way to test the start capacitors mounted on top of the motor? The look normal/no evidence of melting etc... 5 HP 230 V motor. Thanks!
