Capping/sealing workbench ends
maverick302
SE PA
I just put a new top on my workbench. It’s 2 layers of 3/4” particle board skinned with 20ga stainless. I’m pondering what to do to cap the sides. I had intended to leave them bare but once I got it in place and saw it I decided to look into finishing them. I just want to protect it from spills, greasy hands, etc and be more cosmetically finished looking. It doesn’t need to be pretty but it can’t be ugly. I was thinking anything from edge banding and pu, to fiberglass, to a skim coat of spackle and good paint.
What would you recommend and why?
sixty4
CT
I would go with your idea of painting and sealing personally. I would match the color of the cabinets and call it done. :thumbup:
el monte slim
Midwest USA
Paint the exposed particle board in the color of your choice to seal out moisture, then screw mount a horizontal stacked pair of 3/4" x 18" magnetic tool holders to each end of the workbench top. This will cover most of the exposed surface area, and will double up the magnetic holding power for hanging tools at each end. You could also choose to offset the horizontal stacked pairs in order to have the magnets span the full depth of the workbench top.
These are only $4 each at Harbor Freight, and are periodically free with a coupon:
https://www.harborfreight.com/18-in-magnetic-tool-holder-62178.html
http://www.hfqpdb.com/best_coupon/18"+MAGNETIC+TOOL+HOLDER
Miss the Pontiacs
Saskatchewan Canada
It’s proably over kill for your project. But I was able to source some Formica/Arborite type product with a light coating of Stainless Steel. Tough on blades but looks good.
maverick302
SE PA
1MtnGoat
Cleveland, TN
You can buy a tube of aluminum colored caulk and seal the joints after attaching the stainless caps. I don't remember which one but either Lowes or Home Depot sells it.
rsanter
visalia ca
Personally if it was me I would use a stainless strip and have it TIG welded in place.
If you can do that, my next choice would be to bend the stainless in a squared U shape to fit over the wood. You will have to relieve the wood on the top so it will still be flush
rharman
SoCal
Or, undermount 1-1/2" aluminum angle. You could use some filler on the top edge for a cleaner finish.
