TX63CONV
Recently while replacing my 1960’s car stereo with a new version, I went to pull the antenna plug out of the back of the stereo and it separated. It appears this was a two part version with a metal shank compressed on the cable which then snaps or is compressed into the pointed tip (RCA style jack). The pointed tip base has split and it will no longer hold the antenna cable. I had plenty of cable so I cut this piece off in order to take somewhere. Upon inspecting the cable, I see a hollow plastic tube wrapped with copper braiding wrapped with plastic. I expected a center core wire like you would see with COAX.
I have done a google search and I think I need the Radioshack item below but not sure if the cable is still good. The original stereo had ok reception but it has not been used in probably two years.
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=car antenna plug&origkw=car+antenna+plug&sr=1
I really DON’T want to replace the cable….
Thoughts?
Thoughts?
