Car lift never seen one like it
dura eagle
My good friend gifted or long term loaned me a car lift. Not sure what to think about it. He knew I was going to buy a new 4 post lift when I got my shop finished. A friend of his wanted rid of it so he bought it to me. Not what I wanted but the price is right.
it has 4 tall stands that you put under each corner and you can remove the lift. Also included is a bunch of different pads to go on the forks.
Runs on batteries
firebirdparts
Kingsport, TN
The rigid forks would seem to limit your geometry for pickup points.
I have a crown walkie stacker that is just like that, but 1/3 the size and with pallet forks. So it's curious for that reason.
mike93lx
Richmond, VA
If you wanted a four post, that doesn't look like a good replacement. Guess it depends on if free was enough of a benefit. It's going to eat up a lot of space and is no where near as useful as a four post for storage
jack stand
Lakes Region Maine
Better than a floor jack but it's a huge thing to have hanging around.
Show us the pads you mentioned that slip on the forks.
Same with the jacks.
Lou's Garage
Anderson, SC
I have had occasion to use single column lifts and, except for the very lightest vehicles, I was uncomfortable. This lift has a broad column with two widely spaced forks, if anything it should be more stable than the units I've experienced. I'd like to see what it has for pads to the car/truck. J&D Incorporated appears to have been a small fab shop and this lift might have been a one-off custom or part of a product line that had little or local success. If I didn't have a lift and someone offered it to me for free, I'd take it and I'm a bit skittish about that sort of thing as I've already had one car fall on me. Ask the owner about its idiosyncrasies and try it out. If you're uncomfortable, stop using it or use it only for tasks you feel it's appropriate for.
Lou Manglass
P.S. make sure the safety works!
firebirdparts
Kingsport, TN
Me too. Very curious about the attachments and the also the jack stands. I'm guessing no reasonable person would build a jack stand that is actually stable for that purpose. it would just be too big.
Colin Len
Long Beach CA
I'm sure it's awesome for the right purpose but for my needs that would be useless. Its so big I doubt it'd even fit in my garage at all. Free isn't always the best deal. But hard to turn down when a friend is just trying to help.
Viper98912
GA
I mean, technically, yes, you can use one of those walkable battery powered forklifts to lift up something heavy like a car
Old Man Roger
Palm Coast Florida
The one I saw had pads and extensions for truck frames. I almost want to say it might have even had little portable ramps to drive over it if you wanted top leave it in place.
ATC
VA
With a platform on it, that would be awesome for mowers/ATV/SXS/Motorcycles/Golf carts/etc...
drokihazan
This looks like a deathtrap. I'm sure your friend means very well and it's so cool they went out of their way to do this, but I'd have to decline this bulky and sketchy looking thing.
Ryno CW
Texas
This almost looks like a manual hand truck used for barn equipment. I'm not sure even with the outriggers I'd be able to trust this because those arms are not exactly the most stout looking things for lifting a car. Maybe for farm use but I don't know.
mikedodge
I wouldn't trust that thing lifting anywhere near its 6000lb capacity.
With those arms stuck in place you're limited to what you can lift with it then all that dicking around with those attachments... seems like he unloaded it on you because he didn't know what to do with it himself.
Fixr
SW VA
I'd take it in a heartbeat and use it well within its rated limits. I would not use it for a long bed crew cab pickup, but I'd use it carefully for my Highlander or smaller, lighter vehicle, paying close attention to weight distribution. I would definitely use the jack stands to stabilize the vehicle, not as the sole means of support. I've seen considerably sketchier single-sided lifts on the market. All of the ones I've seen in person were bouncier than I liked, and the name-brand one that was demoed at our shop did not get purchased for that reason. This one appears considerably sturdier than that demo unit.
Note that one of the reasons I'd take it is that I don't have any sort of lift. This one could live outside under a tarp and not eat up garage space. I would much prefer a 2-post lift and the shop space to use it, but the portable would beat hell out of what I have now.
Wrench97
Southeastern Pa
Your highlander may actually weight more then a long bed pickup.....
Full size vans can be the hairy ones especially if you don't know what's in the back....
I had a locksmiths van once the 12k lb lift picked it up about 3" and hit the bypass.
Fixr
SW VA
The reason I mentioned extra long vehicles was because the lifting arms are pretty close together, and long vehicles have a lot of leverage when they are nose or tail heavy. My old Highlander is just over 4000 lbs and a lot shorter than a long bed crew cab pickup, and way less likely to have a bunch of weight cantilevered way out at one end or another. For a long heavy vehicle, I would actually prefer a 4 post.
NBN
SE Tejas
The OP lift is similar to a UNIC lift I used for years. Heavy and cumbersome, but useful when you need it. Use it a few times and send it down the road for the price you paid for it. Someone else would love to have it.
NUTTSGT
Northern Central Ohio
Honestly, if it were given to me, I'd take it. . . right to the scrap yard. It would be a seriously hard pass. I'm not putting one of my vehicles on it nor getting under it.
dougf
Missouri
I would happily take it, but I wouldn't use it as a vehicle lift. For my uses of restoring hit and miss engines, tractors, implements, etc... I would lay a 1/2" sheet of steel across the arms and bolt it in place, then use it as a workstation for engines or even a welding and brazing station. If its easy to roll around it would be great for loading and unloading heavy things into a truck bed also. Would save a lot of bending over!
