Car lift with no posts
sparky67
Northern NJ
The town wont let me build bigger then 25x25. So I know I will need a way of storing a car on a lift. I've looked at the 4 post lifts but I dont like that I will have two posts in the middle of the floor I would need to work around even with the car up and out of the way. I see they make one post lifts which look like they would be much better but they seem very limited. I haven't seen one that I could use to service my F150 as well. Also I noticed that BendPak discontinued there model which makes you wonder why.
I am thinking they should make a lift that hangs from some I beams which could be supported by columns in the outside walls of the garage. Something like this:
autonaut
why not a single post lift in the floor?
Edit-
I see you have considered this..
This is one i am using.. The brand does not exist in USA, but im sure there are other vendors selling this type of lift.
I have made several dual exhausts on it. The lift arms are very handy. I just stick a broom across them, and the pipes can then rest on the broom while i wiggle them around doing some welding here and there(for mockup purposes)
LX-Markham
Markham, Ont.
I had a similar problem. Solved it with a double-wide lift. I park my car in the middle, but you could park 2 cars on it, or one car and use the other side for storage.
Posts are on the outside, no posts down the middle of my garage.
http://www.babco.ca/Hobby-Parking-Storage-Lifts/BendPak-HD9SWX
Shadowdog500
Down the shore
What type of safety lock would something like that use if a cable failed?
I have a 2 post lift ant the posts really don't bother me even when nothing is on the lift.
Chris
Anarius
Lifts of this design usually have a self-engaging mechanical lock. Usually a "pawl and ratchet" type. They can be released pneumatically or manually, depending on that particular design. The locks will only allow about a 3" drop if a cable breaks, so no damage below. That said, if the cable breaks its a royal B*TCH to fix.
I've been a professional mechanic for many years, and I have only ever seen one cable break....that cable was from 1996, and was 18 when it snapped on a alignment rack that raises at least 8 cars a day, 6 days a week. For garage and casual use, I wouldn't sweat it for a second.
justme-
Boston suburbs
Contact any classic/collector car insurance agency and ask about liability and coverage for your vehicles on such a lift for storage... might be eye opening. There are lots (and I mean LOTS) of storage lift failures. Many of the lift companies even use examples in advertising. I'd never store such expensive cars on a cable lift - yeah it may only drop 3 inches if a cable fails in the right place, but if the cable fails after the brake/safety mechanism there's nothing to stop it before the car under it.
I'd also ask about the insurance to CYA since finding out your insurance won't cover it is no fun when your lift failed and the Mustang is sitting on top of your Explorer.
redmondjp
Redmond, WA
How can you do that without any rafter ties/collars? What keeps your walls from spreading.
Awesome lift, brw.
I was going to say the same thing - and if there is a ridge beam, it doesn't appear to be supported on the end (other than by a single 2x4).
If there is no structural ridge beam supported on each end, rafter ties are necessary in order to keep side walls vertical.
This image shows the difference between the collar tie and rafter tie:
https://images.search.yahoo.com/ima...=yhs-mozilla-001&hspart=mozilla&hsimp=yhs-001
LX-Markham
Markham, Ont.
Awesome lift, brw.
Top plate of the walls is capped with a pair of 10" structural steel channels on the side walls, and tied together with 3" angle front and back. Essentially, a big square steel frame along the top of the walls for the rafters to push against.
There are some collar ties, but they aren't structural, used them only to square off the top of the ceiling.
Retrofit was performed with the old trusses still in place.
JRC3
Southwestern OH
Ahh, it's hiding behind the deck of the lift in the pics. I've been kicking around a similar idea to raise some of my rafter ties past the 1/3 mark by.
*Edit*
Actually I think the steel channel and angle just looks like it's part of your lift in the pics.
