kenewagner
- Joined
- Jan 29, 2015
- Messages
- 45
I needed a car trailer to haul my car around and having built a few before I decided to build one for myself. I wanted one that was sized for what I needed and with features that made sense for me. I bought a pair of torsion bar axles as I needed the trailer to set low. Built the frame out of 4" channel. I doubled up on the 4" channel to stiffen up the frame. The tongue is 4" channel reinforced for strength and pivots on the frame of the trailer giving me the tilt feature I needed. I built tool boxes into the tongue for storage of the electrical hookups and an air compressor. The hydraulic ram is powered by a hydraulic pump off a large lift gate I had replaced on a customers trailer. Is is also built into the tongue. It is ran by a cable that plugs into a socket at the rear of the truck. Plugs in the front and rear allow me to plug into the controls to run the lift up and down while sitting in the car. The roadside fender pivots at the front of the fender like a gull wing door to allow the car door to open when loaded. unfortuniately I still have to have the pad for the rear tire to sit on to open the door over the tires. The lights are all LED lights for turn and stop. I used small 3/4" LEDS for clearance lights. I installed a 8000 lb winch on the front and built the box to keep it out of the weather. Only had to use it a few times but it was worth it. The front air dam is alum tread plate to protect the front of the car. wish I had made it a little taller. The tires are heavy duty multiple ply for the long haul. Tie downs are built right into the frame and spaced for the best use on the straps I have to tie my car down with. I stayed with a wood deck as I get a little better traction driving the car up on it, its also easy to replace in the future. Pulls like a dream, don't even know it behind you going down the road. Now I have other friends wanting to know when Im building them one, lol
Ken
Ignore the drum picture, uploaded it by mistake
Ken
