wafrederick
Brake cleaner is also good for something else,killing small bees nests.Spray them with brake clean,the bees go dead quickly.If you don't have a can of the spray to get rid of bees on hand,use brake cleaner.
Brake cleaner will only melt certain plastic and rubber. Here is a handle on my cm plastic tool box and a plastic seal.
Question If I ran out of brake cleaner can I use CRC throttle body cleaner to clean off my flywheel?
Surprised someone has not mentioned this already:
Do NOT use brake cleaner to clean parts prior to welding. The off gases can kill.
You probably could but throttle body cleaner is alot more expensive than brake cleaner ...
So are there different applications or reasons for using chlorinated versus non-chlorinated brake cleaner?
