Carbon Fiber Wrenches
85FourEyedGT
Oakland/UC San Diego
http://carbonlitetools.com/
Saw an article recently in Popular Mechanics on these wrenches, they look really cool and weigh almost nothing.
Still cant find a legitimate reason to own them , but hey thats never stopped anyone :bounce::bounce::bounce:
southalabama
Brewton AL
I'm not sure I would have a need bit I could imagine a special forces guy having a need for some specialized mission.
n8n
Curtis Bay, MD
Those would be great for a traveling tool kit... But I would be worried about impact damage...
Sent from my Nexus 7 using Tapatalk
2xs
Yeah there kind of expensive and only closed end seemingly useless to me at least.
racecar
Those tools would be great for people having to actually carry them around on job. Carbon fiber keeps getting lower priced. I love the stuff.
85FourEyedGT
They do warn against using cheater bars on them and the possibility of splinters, I do find the open end only being a limitation seeing as not all bolts are that accessible. Also I wish they were ratcheting!
G_P
Central CT
Might make a good set of tools for a bush pilot who may have to make emergency repairs after landing in the middle of nowhere. Light weight would be a big plus in a small airplane.
azhatchback
Yep, I own a 85 GT Hatch and a 2003 Cobra Coupe :3gears:
Nice I :drool: over the 85's. I like the 86 too but prefer the 85 as it was the end of the carb era for foxes. I got an 88. I just gutted and smoothed the engine bay. It's getting a carb. I cut most of the fire wall out and replaced with 18 gauge to get rid of the pinch weld, bead rolls, and other lumpy areas.
View media item 39963
85FourEyedGT
Haha wow!:bowdown::bowdown::bowdown:
that is an absurd amount of work but it looks great!
I also think 85 is the best, last year of the carb, first year of the roller cam!
azhatchback
All the 85 needed was the 8.8!!! To bad it went to the 86.
Thanks for the compliment. It was an incrediable amount of work. Started as a simple carb conversion and spiraled way out of control. This bay was ugly. The car has a nice 3 stage, color sanded paint job but the under the hood was not matched when I bought it
I welded up all the small holes on the towers and frame and then I went stupid. I decided to cut the fender aprons out because they were not worth patching. Then I did the rear aprons. Then I plug welded the small holes on the firewall and patched the AC/heater box and wire harness holes. I cut, welded and leaded the pinch weld. Never ever do this unless you are up for a ton of work. I striped the interior and had to use a torch to remove all the seam sealer and sound deadning junk so the welds would not be contaminated. I was not happy with the fire wall results when I was done so I cut it all out and made my own fire wall from a sheet of cold rolled 18g. Now it was flat and smooth. I kept some stock aspects such as weep holes at the top, windsheild wiper, junk etc... hoping to fool track officals that the firewall is stock so I don't have to cage her. My cam is just barely capable of making enough vacuum so I kept power brakes. I also made new brake lines so their out of sight, got rid of the stock proportion valve and mounted a manual one behind the drivers strut tower, relocated all the wiring, solinoid, msd box, a terminal block accessory set up behind the dash where the heater box used to sit. Still not done with the wiring. All the wiring into the engine bay will be in that one gromet you see by the tunnel. I also pushed the sides of the tunnel back a couple of inches so the longtubes are easier to deal with. Prior to this I had to hammer the tunnel to fit the headers. Looked like ****. I removed the front sway bar mounts so the frame rails look really clean. I cheaped out and painted stock K member vs. tubular. That pic is where I had just squared K member back in. That is why there are two tape mesures on the floor.
I was going to turn it into a drag car but I decided to keep her on the street as I want my boys (3 & 6 years old) to ride and enjoy it with me since they help me work on it. My 6 year old has been driving the cherry picker for me since he was 4. I just taught the 3 year old how to use a floor jack. He will be ready for the cherry picker soon. My 6 year old is pretty good with tools now. I let him put all the sheet metal and covers on the engine as we tore it back down to adress some issues while we were at it.
Been with out my car for 3 years in July :shocking: I had a heavily modified 73 camero before this and I drove a fox my buddy bought, 3 hours back to phoenix and fell in love! I was a ford hater before this! Now I eat and breath fox bodies. Though I want to do this same thing to a SN95 cobra. Ok back to the tools sorry.
Before pic:
View media item 39961
PETE14
Denver, CO USA
Meh. Seems pretty gimmicky to me. Unless there is some kind of clear coat on them - which there doesn't appear to be - I would think that oil and grease would soak into them and make a big mess in short order.:(
organ
Atlanta
Soak into them? They aren't made of paper; that's not how carbon fiber works.
autonaut
I love these kind of years.. Where 1 thing ends, and another one starts.
For me, it's an 87 el camino. It's carbed, but with a roller engine block..
Great looking engine bay.
quattroJoe
FL
Been thinking, if it weren't for the cost these would make pretty cool handles for garage cabinets or toolbox drawers.
