dr_clyde
Last spring a fellow member here ended up with a collection of miscellaneous stuff, and he posted pictures of his haul. My metal nerd eyes spied a Cardinal Speed Vise in amongst his hoard of interesting stuff. I inquired as to it's availability, we settled on a fair price and I ended up with it. It was rough, but well within the realm of save-ability.
For those not in the know, the Cardinal is (IMO) one of the best drill press vises made. It has a quick acting buttress thread on the lead screw allowing for expedient and easy travel between minimum and maximum capacities. The unfortunate truth about good quality tools is they tend to be expensive. The Cardinal is no exception. A new one of these buggers will set you back over $500! So, the hunt is always on for used ones. They make several sizes, but I think the 6" (which this is) is best suited to general job shop drilling.
Here's some before and after pictures.
As you can see, it has led a hard life. Some bozo was using it to hold something while soldering or pouring a lead casting, because there was a bunch of lead on the back jaw. Fortunately it just melts off.
Cardinal vises are cool in that you can replace the bottom plate if needed, its just cold rolled. I just flipped it over, hiding all the drill divots. If I ever need to, I can just buy some more steel.
After blasting, I noticed some dweeb had welded on a washer to the back clamp hardware slot.
That had to go. WTF is wrong with some people? A bit of grinding and it looked good enough for paint.
All told I cleaned it up, bead blasted it, repaired any dinks and marks of shame by brazing, and gave it a paint job. I also machined a set of CRS parallel jaws, as the hardened factory jaws were missing.
Right at home on the 20" Walker Turner.
Thanks for looking.
Thanks for looking.
