Some of those trikes, I'll be darned if I can see how they steer???
I'm still trying to figure out how to hide a motor on a regular two wheeled bike. More and more places aren't allowing motorized vehicles of any kind and I'm ok with that 99% of the time, the other 1% being when I'm pulling the kid trailer full of whatever, I could use a little help on the hills every now and then and asking forgiveness is sometimes easier than asking permission.
I've thought of hiding a long, thin motor with a planetary gear set in the down tube with a 90 degree bevel gear drive at the bottom bracket but the tooling to get everything fixtured and aligned to the required tolerances would be cost prohibitive. The simplest solution I can think of is a motor hidden in a bag on a pannier rack, mounted close to the seat post, driving a chain run around a sprocket on the leftcrank arm. It would require most of the reduction to be taken care of in a gear box with another 1:4 or 1:5 between the gearbox spindle and the crank arm sprocket. The given speed of the crank arms doesn't change significantly as we just shift gears to maintain a comfortable rpm and it could have tremendous motive force in first gear on a 24 speed mountain bike.
My preferred design is pictured below.
I see a need for the front wheels to tilt during turns, but so far I not found any close up pic's for me to get my head around how it is best worked out.
This design is not the articulated type it has it own front axle with individual turning wheels like a car or go cart, with the exception that they tilt as well.
I figure if I have an electric powered version it will need to be able to cope with speeds faster than pedals alone and the articulated style which I actually like is not up to the task in my view.
If any body finds helpful pic's please post them here for me.
I think youd run into issues with gear binding as you have two wheels making turns at a different radius. Maybe not a big problem but i would not want expensive motor driven wheels involved. Especially since you could do all the driving with the rear easily with conventional parts.If I ran 2 x 20" front wheels both with electric hubs, would I have any trouble being able to turn with the articulated steering???
