Started the repair of the hot water pipe that feeds the house and grainery. It took me a few hours to uncover them. There used to be an outside multi-fuel burner and the pipes were extended when I built the shop. This last winter I had a pump fail and the boiler turned into a steam engine and burst the outgoing PEX just under the cement. I put in a splice and wrapped it with an old blanket and a bale of straw for the rest of the winter.
The black pipe has two one inch PEX pipes inside wrapped in insulation. The one that goes to the house is 170 ft long. The temperature drops 1 deg by the time it gets to my water heater heat exchanger.
, he always denied he hit that pole but we knew he did when he backed into the alley to turn his car around.
