VdubbG
So we bought this house in June. first it is the garage. Hired a contractor to do this job.
Picture of the house.
Day 1
Day 2
Day 3
I have low ceiling height. There is nothing above there, so i eventually plan on putting a pull down stairs and insulating flooring above for storage.
So I have a few questions. The existing structure was sagging or sloping. I'm not sure if its because of the existing structure or because the concrete slopes to the rear of the property. So maybe the ground has settled over the years. The house was build in 81. The contractor as you can see did not add any beams should I be ok to put storage above. There is more support than there originally was, but also added weight with 2 garage doors and eventually storage.
Some pics of what is existing...Should this hold for several years without any trouble? or should i look into a lvl beam in addition to what already exists?
in the front it looks as several 2x4 stacked with a metal mesh holding them together.
in the back it looks like 2 2x10's with some sort of 2x4 on top
Day 1
Day 2
Day 3
