Yep I have. And I use the hell out of 7/16,1/2, 9/16 , 3/4 and 15/16 and 1-1/8. So I have those in my bag and gear wrenches in the smaller sizes. I got a bucket boss wrench roll at fleet farm tonite I’m gonna try out. See if I can’t make them all fit.Wrench rolls.
You may find out you're only using specific sizes for your job, so no need to haul around extras if a handful of specific sizes in a couple of pockets will work. Have you started the new gig yet?![]()
Wrench Rolls | TEKTON
Shop wrench roll organization options. Each roll has wrench slots marked with inch or metric wrench sizes.www.tekton.com
Yep, takes up less room than a roll when stored, and more importantly way less room when opened out for use.The Facom 440s in the foldable plastic rack![]()
I do like those a lot. If the roll doesn’t end up working out I’ll be snagging those. Maybe the wrenches too. It’s been interesting going from a 3 bay snap on tool box as a diesel mechanic. To a tool bag and a truck working in basements at a plant lol. I love it thoughYep, takes up less room than a roll when stored, and more importantly way less room when opened out for use.
The holders are sold separately, they might work with other brands but may need a bit of carving.
That’s a quality Looking wrench roll wow
It is, and its also relatively cheap. The plastic wrench rolls generally don't last as long in the field, the plastic gets brittle and the seams separate. This one is waxed canvas and has held up very well over the years. My only suggestion would be to have brass clasps, but the plastic ones haven't broken and don't appear to be stressed, so a brass buckle or clasp really isn't needed.That’s a quality Looking wrench roll wow
Thank you so much! I appreciate the help. I wil say right now I’m carrying 8,10,12 inch adjustable wrenches. Do I need all 3? Prolly not lol. I’m just so used to working on trucks and having my huge toolbox right in front of me lolI keep them in a pocket in my tool bag. The junk I work on I only carry 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 7/8, 15/16 wrenches. They fit nicely in a pocket in the bag and I just grab the size I need quickly without having to fumble with a carabiner or a roll. Rolls would be a pain to roll out every time I need a wrench. My punches and chisels are in a roll and it's a burden to get them out though I don't use them often and it keeps small tools from running away when your bag gets dumped over. I just carry combo wrenches and semi deep sockets/ ratchet. I don't feel the need to drag around ratcheting wrenches every day with the junk I work on, you may find you can't live without ratcheting wrenches or only really need a couple sizes of ratcheting wrenches.
If I need a wrench that isn't in my bag I've got an 8" snappy wide mouth in my pocket and a 15" automotive wrench in the bag. I highly recommend carrying a 15" automotive/ f wrench instead of a big adjustable, crescent makes them. They go up to 3 1/2" and are pretty durable. If it's a bigger job I'm usually bringing a bucket of tools and will throw in other sizes, metric wrenches, or my angle or ratcheting wrenches already in rolls in the bucket.
Before you know it your bag gets to be 100 pounds if you aren't picky about what you put in it. Lighter is better when you have to pack the thing around all the time. Every couple months I'll go through the bag and reconfigure what I carry pulling things out I haven't used to reduce weight. I've got a couple save my *** tools I don't use often that will stay even if they haven't been used for a while. The longer you work on the same junk the better idea you'll have of what you want to actually pack around every day. There's times after the 4th time I've forgotten a tool for a job it just get added to the bag instead of forgetting it again. My bag is about ready for a purge again, I think I can free up a couple pounds
Some things I've done to reduce things I carry are:
-Replacing multiple Phillips screw drivers with a single ratcheting screw driver with interchangeable bits in the handle
-Combo side and flush cuts instead of side cutters and a flush cuts
-Semi deep sockets up to 9/16" in 1/4 drive with 17mm, 3/4, and 15/16 in 3/8" with a 1/4" to 3/8 adapter and a 1/4" ratchet
-straight pry bars serve as a chisel, punch, and line up bar in addition to a pry bar
-8" wide mouth adjustable 15" F-wrench instead of 8", 10", and 15 or 18" adjustable wrenches
i suggest keeping a list of what you worked on, and what tools you used. Also track what you wanted to have, and anything you had to go get. Even if you don't add them to the standard kit, you can bring them if you know you're going to be doing that job again. You can also spot the patterns of what you're not using, and do some culling.Before you know it your bag gets to be 100 pounds if you aren't picky about what you put in it. Lighter is better when you have to pack the thing around all the time. Every couple months I'll go through the bag and reconfigure what I carry pulling things out I haven't used to reduce weight. I've got a couple save my *** tools I don't use often that will stay even if they haven't been used for a while. The longer you work on the same junk the better idea you'll have of what you want to actually pack around every day. There's times after the 4th time I've forgotten a tool for a job it just get added to the bag instead of forgetting it again. My bag is about ready for a purge again, I think I can free up a couple pounds
You aren’t wrong there. A lot can be done with that. That’s why I’m trying to trim my bag down. We work 30-50 steps down in basements a lot. So I generally bring my bag because I’m not walking up and down every time I need something like some of the guys do. So I’m really just trying to dial it in lolI keep an 8" adjustable, 7" knipex, pocket pry bar, and utility knife in my pockets. I can fix a lot of stuff without my tool bag. After a while you'll get sick of dragging around a ton of tools you barely use.
Yeah my grandfathers were milwrights. I get it. Glad we have more organized and tougher stuff now though and more comfortable to carry
1970's, stores stock toolbags were issued to all the maintenance trades. As an apprentice you were honoured with carrying that everywhere. Often overloaded unnecessarily.
Up onto crane gantries, under presses in between huge parts of all kinds of machinery.
Hammer head twisted in handles and hoisted onto your shoulder.
You were NOT getting out of the task.
