CGT80
This pump is on a 120 gallon tank I picked up for my WABCO-dresser-leroi 2AVC/400. I can not make out the numbers on the front and have not seen one quite like this on GJ. It is similar in size to the WABCO 400 which is a 5hp pump and it accepts 3 belts. I would guess this is a 5 to 7.5hp pump. It certainly appears to be single stage. While it looks a little cheap or like a knock off and the valves are under the top plate, it is cast iron and isn't as generic looking as some. It certainly doesn't match the looks of the two WABCO compressors I have or the other big name brands who make industrial quality pumps. It turns fine by hand and moves air. I haven't had time to open it up and check the valves and bore/stroke size. Does anyone recognize this pump and have any specs on it?
https://www.garagejournal.com/forum/media/20220204_152322-jpg.114300/
