Cast Iron Spokeshave from England
patack2
virginia
Hello,
Can anyone tell me how to read the number on this spokeshave? Are there bars on either side of the number which would make this #5? Or?
Does anyone know the English manufacturer?
I look forward to your thoughts.
Many thanks.
Yup, Stanley 151 missing the cutting bit and the lever cap. 1 easily bought, the other easily made.
You can see the cap here, big chunk o metal, a hacksaw, and some files, and good to go.
Or probably find one on Ebay if you are in a rush.
neophyte
Pennsylvannia
Looks like a Stanley 151.
This.
At a certain point, all the “better” Stanley woodworking tools started to be made in England.
The Spokeshaves were one of these.
To use that, you need a blade and a blade cap and screw.
Older Stanley English made blades held a good edge, but you needed to remove a stubborn lacquer coating before using the blades, and then either spend a crapload of time flattening the blade, or you needed to slightly back bevel the blade, using a method similar to that taught by David Charlesworth.
Nowadays, an aftermarket blade by Hock, or Lee Valley, etc. would probably be worth it.
You would also likely need to derust the spokeshave (not hard using Evaporust) and flatten the spokeshave sole.
Buying a new spokeshave might be just as cheap, and easier.
WisJim
Menomonie, WI
At some time in the past I bought a lot of plane and spokeshave bits and pieces, blades, screws, etc., at a hardware store going out of business sale, and if needed I can check to see what I might have on hand. I think I had a box of blades for 151 size spokeshave, probably "made in England" stamped.
Stanley used some odd screw and thread sizes on their fasteners, and I have no idea if old Stanley "made in America" threaded parts would work with newer Stanley "made in England" tools.
Edit to add--found them, took a picture
  • Like
Reactions: RTM
P
patack2
virginia
If you could check, that would be wonderful. My intent is to clean this up and sell it. I am probably most interested in the cap and the cost. Thanks.
Dave455
Sussex, England
With regard to planes, the threads are actually Whitworth threadform.
Stanley inherited their plane designs from Bailey. Leonard Bailey first patented planes in the 1850’s, so used a standard thread of the day. But this was before the Sellers thread was conceived, and long before it became standardised in the U.S. as “National” threadform.
Stanley continued to use those threads till the end of U.S. production. The British factory used the same threads, as it was no drama for them to use a Whitworth thread, although some of the sizes (I think 9/64 was used) were “non standard”, as were some of the thread pitches (I think there are some that are neither BSW or BSF).
Some later Stanley tools used threads from the American National “Numbered” series that are now obsolete (the larger ones that overlapped fractional sizes) but again, that was standard for the day.
Some tools produced by the British factory were revised to use metric dimensions in the 1990’s. Examples are the “Yankee” screwdrivers, where a “B” after the part number indicates it uses metric sized bits. Personally, I think this was a daft decision, as every Yankee screwdriver from an original North Brothers, to a late 80’s tool uses the same bits, but the newest don’t!
Don’t know much about Spokeshaves, but I suspect U.S. and British tools (with a question mark over the very newest) use the same threads.
Taps and dies for Stanley threads are available if needed. I’ve encountered a couple of tools where threads appeared to be different, but in reality just needed cleaning out!
Some parts were metric threaded on England made planes. I had a junker 78 rabbet I brought back to life, and bought a fence and rod, made for the made in England series. Metric threads, retapped the hole, and away we went.
neophyte
Pennsylvannia
To be fair about Whitworth threads, they were designed for cast and wrought iron, which is what the planes are usually made from, do it’s a better thread design for the material, and possibly just a better thread design overall.
neophyte
Pennsylvannia
It’s probably not worth it unless you know someone who really wants a Stanley spokeshave.
The handle might be worth something to someone who dropped and broke theirs.
  • Like
Reactions: RTM
neophyte
Pennsylvannia
Stanley sold the Yankee Trademark to Walter Schroeder (sometimes spelled Schroder, or with an Umlaut over the “o”) Gmbh of Germany.
Schroeder was the main manufacturer in Europe of the spiral ratcheting screwdrivers for decades after Stanley stopped manufacturing the Yankee screwdrivers in England and USA, and Schroeder was the company that made the screwdrivers for Craftsman, as well as for brands like Facom.
I think Schroeder has mostly switched to just making the screwdrivers to use hex bits nowadays.
Yup, typically those go $15 to 25, so definitely don’t go there to make money. I personally don’t see the reason everyone loves them, but my expert friends tell me they are great.
P
patack2
virginia
Thank you, Dave, for all that great information. Can you explain "threads" for me. Does that have to do with plane handles and knobs rather than spokeshaves? Sorry for the delay. My internet went down. Boy, you never realize how much you use it!!
P
patack2
virginia
Thank, you for your help.
Dave455
Sussex, England
Yes, I was referring to the “odd” screw sizes that WisJim mentioned, which are predominantly found on planes. There are the screws holding the handle and front knob, another holding the cap iron, and the depth adjustment screw.
You may find similar on spokeshaves, but I can’t be sure. I have examples of most Stanley planes that I can check, but I don’t have many Spokeshaves, and certainly not British and U.S. examples of the same tool!
The relevant point is that, in most cases, the components of the British produced Stanley tools are interchangeable with the American produced ones.
P
patack2
virginia
Thank you. I am a novice, but really love woodworking tools.
Dave455
Sussex, England
With the exception of power tools, I hardly have any newer woodworking tools.
Unless you spend serious money, the older tools are generally far better made. If you take the time to keep them clean and rust free (not to mention sharp) they will serve you well.
I’ve probably “wasted” far too much time cleaning up and refurbishing old tools than should theoretically be justified, but I’ve unwound after a stressful day, entertained myself for little cost, and have some some very useable tools.
Here in the U.K. I can acquire new, British made, blades for any standard (Stanley / Record) spokeshave. I’d be surprised if the situation was vastly different in the U.S.
