cast iron to copper air lines
pillguy
Metro Atlanta
Hi all,
I have a question on connecting black iron pipe and copper together. Can I do it or is there anything special I need to do?
I sear he'd but could not find anything spe ific on the forum.
The reason I am doing this is to make a cast iron manifold to dissipate heat and moisture right out of the compressor.
Thanks
38Chevy454
Cincinnati, OH
Copper is a much better heat conductor than iron. Iron is good for vibration dampening vs copper, but I would just use copper for the whole thing.
Bobdog
South Jersey
Of course you can.
You just need to thread the end of the pipe and use a copper sweat x pipe thread adapter. In the case of big pipe, you would use a companion flange.
CNGsaves
KS and OK
Sounds like you're trying to re-invent the wheel in terms of making your own Franzinator.
Use GJ black line at top for Search, then scroll down to Advanced Search, and put in Franzinator airline and you'll find lots of threads.
For DAYS of reading, just Google as follows:
> > > > Google > > > Franzinator
larry_g
oregon
you need a dielectric union between the two
You sure? I've never seen one for any copper tube that runs from the cast iron pump head to the steel tank. Never seen one on a cast iron engine block either.
Can you provide a recognized source for your statement?
lg
no neat sig line
P
pillguy
Metro Atlanta
Hi Guys,
Thanks for all the comments. I ended up finding the franzinator threads and was able to pick up parts yesterday. Worked on putting it together, but one challenge has been installing pipe on either side of the double tapped bushing that goes into the mallable T fitting. The thickness of the casting limits the length of the threads for installing both pieces of pipe. I will put up a picture or two.
Thanks for your help.
Saved me about $150
P
pillguy
Metro Atlanta
Here are a few pictures
Here is the other showing the inside of the double tapped bushing and the lack of threads to install the remaining components.
This is what I cannot install
Sent from my Nexus 7 using Tapatalk 4
RPH
Michigan Thumb
Dielectric union are used to stop the galvonic reactions between dissimilar metals. Has nothing to do with the electric versus gas. Plumbing code requires them when going from one metal to another. Iron to copper or galvinized to copper.
Alchymist
Central PA
Used on electric water heaters because of the potential for stray electric currents through the pipes, which causes the galvanic reaction. If there is no electrical force, no reaction. Very unlikely in a compressed air system. Most compressors use a flex hose of some type between tank and piping anyway, lessening the chances of galvanic action even further. Never ran across a dielectric union in an air system. YMMV.
