Casters for a gantry hoist
kbeefy
Harington, Eastern Washington
yes, 4 swivels with brakes.
Do they make swivel casters that can be locked into a chosen oreientation? That would be cool, my gantry is always trying to go a direction I don't want it to, much easier to move with 2 people.
tarmy
Nor Cal
Get the good ones that won’t flat spot.
ER Wagner or similar…
dutchgray
Dorset. England.
I would get casters that can take the whole intended load individually, that way when you have 4 on there you have a decent safety factor.
p00p
42.4974° N, 82.8964° W
The local u-pull it has casters that are about 10" & swivel. Those go thru a hard life & U suspect those would be ideal. IDK where to get those or if they have a brake & lockout option.
blazemaster83
Lacey, Wa.
I have a 3 ton wallace gantry. It came with 10" swivel casters that had no locks, they were a hard plastic. I replaced them with some casters I got from a boeing auction. The new ones were 12" and have directional locks, they have softer tires and are rated for 3k lbs each. If you have directional locks you can use them to lock the crane in place.
b-dog
Lakewood, CO
Yes, definitely opt for the swivel lock! I can lock both casters on 1 side and push the gantry solo from the other side. I can't imagine trying to make the gantry go where I wanted without the swivel locks, it would be a circus.
Size the diameter for your surface. Generally larger is better. Unless your surface is relatively smooth, I'd go 8" minimum.
I have nylon wheels and they've worked well for me. That decision was partially based on storing the crane outdoors and budget.
