Casters
StevenB
CA
I'm curious where's a good place to wheel casters?
Want to get a 5x2 caster set, 2 swivels & 2 locking swivels. Going to build a new mobile welding table.
Thank you.
A_Pmech
IL
What is your budget?
Aye! This is the most important specification. There's two orders of magnitude between the cheapest 5" caster brand and the most expensive 5" caster brand I can think of.
StevenB
CA
The one's I've came across have a load rating 800lb. My budget is stay $80 for the set.
MillerMav
Craigslist!
There are all kinds of independent guys and small shops that will pull casters off of equipment to install them on something that already has casters. Or junk collectors who pick them up at auction then sell for a small profit.
In recent memory from two different guys I have got...
1 set of 4 - 4" Rubber on Cast ball bearing swivel/lock casters
1 set of 4 - 6" Rubber on Cast ball bearing swivel/lock casters
1 set of 4 - 4" Poly on Cast ball bearing swivel/lock w/swivel lock casters
All said and done $80 total. You can never have to many casters!
kbs2244
I second H F if you have one close.
It is one of the things they do well.
Sure, they are made in China.
But they are not very complex and are good quality.
kazlx
Tustin, CA
Thank you.
Where in CA are you? If it's SoCal, I have a local place I go to that is very reasonable and have anything you could want.
Vegaman_Dan
Pacific, WA
Some of the better casters at Harbor Freight are not sold on the shelf with casters, but instead come as part of the four wheel moving dollies instead. It's actually often cheaper to buy the dollies, yank the wheels off and have a good set for little investment.
astroracer
Mid_Michigan
EXACTLY! Buy the small dollies for 8 bucks on sale...
Here are a few of the dollies I have "repurposed" ...
The welding/grinding/assembly bench I built out of a trash picked vanity
Cut down a full size dollie and bolted it under my tubing bender stand.
The engine for the van is sitting on a full size dollie. The cradle is screwed to it so it won't come apart.
The trans and GV unit are also sitting on one as is my arbor press.
I even used a small dollie under my roll-a-round work stool after the cheap casters blew out.
Mark
buening
Decatur, IL
I had good luck with sescastorco on ebay. http://www.ebay.com/sch/sescasterco/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
I bought 4 of the total lock 4" stemless castors for my 80gal air compressor and they handle the weight with ease. The locks work well as well. For $8/ea, you can't really go wrong. The total was $43 shipped. I couldn't find a total locking caster at Harbor Freight, and the ones I found that had swivel locks had a plastic lever....
