wesst
Reposting from general forum, as this may be electrical specific. I have a question someone may have an answer to regarding a new CAT air compressor.
The compressor runs fine upon start up and shuts off when full. It will restart when pressure drops as designed.
If I start the compressor and turn it off with the manual switch on the compressor at any psi less than max, the head pressure is relieved via the pressure unloader valve (CAT calls it the easy start valve) near the pump head. It works as intended.
I connected the air compressor to a switched garage outlet so I can turn it on and off from across the garage with a remote switch aligned with the lights switches for my garage. I did this with my old Craftsman air compressor and it worked great.
The issue I have with the new CAT compressor is if I shut the switch off before it reaches shut off pressure, the motor will not manually restart because pressure cannot be relieved from the pump head. The pressure will not bleed from the “easy start valve” located by the pump head when using the remote switch, but will if I walk to the compressor and manually turn it off at the actual pressure switch. My old Craftsman compressor would operate from the remote switch at any psi.
I am reaching out for insight from those more knowledgeable than myself as to why this will not operate from the remote switch. I was also looking into a load genie valve as well, but not sure if that would work. I thank you in advance for your time and feedback.
