pizza
i need some advice on fixing this hazard. i believe it's called a circular catch basin – is that right? or manhole?
i believe this access point is for a storm drain that probably incorporates an adjacent driveway drain, and it communicates with my house sewer because i know it's possible to rod out the sewer from here (going through the house and then out to the street / city sewer). i hire plumbers to do this every so often because tree roots are bad around here. however, now i have a tramco backflow preventer setup in my basement (unsure of precise name for this style of system), so you gotta lug the machine downstairs to a cleanout just downstream of that.
the steel manhole cover is gone. i don't think it actually fell in the hole because i looked with a bright light and can't see it down there, but i'll try dangling a magnet on a string for fun. i have a pretty good idea of who probably stole it. oh well.
it was a solid, circular, steel cover, btw. not a grate.
the cover was kinda wobbly on there though, so it's time to replace it before someone falls down there and takes my house. lol
for now, i have an oversized obstacle that does a great job of covering it.
i got one estimate so far:
what do you think of that estimate for chicago?
how DIYable do you think this is?
any recommendations for suppliers for a ring and cover around chicago and what they might cost?
i found one promising lead so far:
www.franklinparkbuildingmaterial.com
besides the ring, steel manhole cover, some bags of concrete, and something to mix concrete in, what tools and supplies might be involved? what would the procedure be?
also, what was the failure mode? the concrete shifted/settled for.. unknown reasons? freeze-thaw, something-something?
thanks, guys
Replace Basin Ring
Remove broken catch basin ring.
Provide and Replace 30" concrete catch basin ring and steel cover
2 men, all day
$3700
Franklin Park Building Material | Precast
Patio Block | Chimney Cap | Catch Basin Cover Ring | Rock Faced V-interlock block | Fire Department Stamped | Smile Stamped
thanks, guys
