CATX termination tools
jal395
Raleigh, NC
I just finished pulling some CAT6 STP and need to terminate it. What tool can be recommended for this?
J
jal395
Raleigh, NC
Sorry to be too vague. RJ45 terminations. As for the brand I think it is from Comtran cable. I have no idea if they manufacture or only distribute.
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
J
jal395
Raleigh, NC
Thanks for the replies so far. The application for the shielded cable is to run an HDMI signal from a computer to a projector 225 ft. away. Any other advice or experience is welcome.
jeffmoss26
Cleveland, Ohio
I've been doing cabling for years and never had to terminate any shielded. I would think any crimper can terminate the shielded mod plugs.
225ft sounds fairly far, assume you are using HDMI extenders?
This should probably be moved to electrical.
J
jal395
Raleigh, NC
I think jeffmoss is right in that any crimpers will work. My question is mainly would a different tool handle the extra bulk of the shield and drain wire better than my old telemasters. And then the question of what do you do with the shield and drain wire.
Kramer VM114H4C to transmit
Kramer TP574 to receive
scaron
ypsilanti, michigan
if you want to terminate plugs, i'd suggest the ideal crimpmaster with the requisite die. it's got a ratcheting action and can really put the pressure down for a good crimp... i know the CAT6 is a little harder to work with... for terminating jacks and patch panels, it's up to you; you can get a little plastic punch tool (sometimes a little one is even included when you buy a big package of jacks); klein makes a nice manual punch tool; or, i suppose you could set a spring punch tool to 'low' and try that, though, you have to be careful not to blow up the jacks... the spring tool is more for e.g. 66-block or 110-block. bottom line is, though the procedure and jacks/connectors are a little different for shielded cable, you use all the same tools as for unshielded.
