Caulk or ?
lbperry
North AL
Had some crown moulding installed a couple of years ago and a few of the miter joints have separated enough to be noticeable (to the wife). What’s the best filler to use to get a good repair? Got a recommended type or brand? Color is a a gloss white.
Thanks for any recommendations,
LXCam
I prefer paintable DAP since it’s water based you can easily clean up a mistake and smooth it out. The downside is it does shrink when doing larger gaps so you might need to apply it a couple more times to dial in the look.
PoorUB
Fargo, ND
I second the paintable DAP. I just installed a couple hundred feet of base plus trimmed nine doors, all painted trim. I am not that good or that patient and end up with a crack here and there, DAP was my best friend!
Glemon
NE
I would go with some of that dry spackle that you just wipe on/push in the gap, then wipe off the excess and done, white on white you will not notice it is not gloss for an 1/8" gap or whatever. I have used it to fill corner gaps and wall gaps on a lot of white trim. Super easy to work with https://www.amazon.com/dp/B0006MXS0Q/?tag=atomicindus08-20
gizardlizard
Madison, WI
White lightning megalastic sold at Sherwin Williams. The beauty of that stuff, is that it can stretch 700% without cracking. It tools super awesome too.
nadogail
Coronado, CA
I would try that product, if I sure it paintable.
Like other trials, try a small sample in an inconspicuous area.
Kaizen
New England
I’d wait till mid summer moisture pulls the whole house back together. Then pry apart and put glue in the problem joints.
